Hi all,
I am using the teensy 3.0 with the teensyduino IDE add-on. I have been trying to establish a serial connection to a sim900 breakout board I purchased a few months ago (this model http://store.open-electronics.org/Breakout/GSM Breakout/Breakout SIM900 GSM Module ).
Once the sim900 powers up I successfully receive this in the serial monitor
RDY
+CFUN: 1
+CPIN: READY
+PACSP: 1
Call
Though the problem is when I try and send an AT command to the module such as "AT". The module always sends back gibberish.
In particular sending "AT" cause the module to respond with
My code
It would seem to me that the problem is sending from the teensy not receiving. Please note that I have successfully used a 3.3 volt Arduino to interface with this module using very similar code and when sending "AT" the response was "OK". Have I implemented the teensy's serial function incorrectly? Why can I only receive?
Thanks
RDY
+CFUN: 1
+CPIN: READY
+PACSP: 1
Call
My code
char incomingByte;
char incomingComp;
pinMode(8,OUTPUT);
Serial1.begin(2400);
digitalWrite(8, HIGH); //power on for sim900 on d8
delay(1200);
digitalWrite(8, LOW);
delay(10000);
if(Serial.available() > 0) { //print data from computer to sim900
incomingComp = char(Serial.read());
Serial1.print(incomingComp);
if (Serial1.available() > 0) { //print data from sim900 to computer
incomingByte = char(Serial1.read());
Serial.print(incomingByte);
Thanks
