Teensyduino 1.15 Released
Thanks!!! Good Job!!! ¿there exist some "revision control" to contribute or get some devel branch of Teensyduino?
Make sure Teensy Loader is not running. Then click Verify in Arduino, so the Teensy Loader installed by Teensyduino runs. Look in the Teensy Loader's verbose info (help menu). Prior to 1.15, Teensy Loader had a different version number from Teensyduino. Now they're in sync, so if it's Teensy Loader 1.15, then you have Teensyduino 1.15.
If you have Teensy Loader 1.07 or older, look in the comments when you do an upload. When the Teensyduino utilities send the filename to the Teensy Loader, the version of Teensyduino should be shown.
Thanks, that was quick!
Loader = 1.07
Teensyduino = 1.13.
Cheers.
