View Full Version : "Error reading Teensy Loader status! (tr)This error should never happen."
pictographer
06-29-2013, 11:14 PM
My ability to update the program on my Teensy 3 is intermittent with various failure modes. I've included as much output as I can find below on a recent one. I work around this by retrying the upload, unplugging the USB cable, or power cycling the T3. I haven't counted but upload problems happen several times an hour when I'm uploading code frequently.
Sometimes, the Arduino environment reports a "shouldn't happen" error. Sometimes it claims the Teensy Loader is busy. Sometimes when it claims the Teensy loader is busy, it works anyway. Sometimes the Teensy loader hangs erasing the part. There isn't a single consistent pattern to it.
For what it's worth, I also have trouble connecting the serial monitor both from the Arduino environment and from the command line using the cu command, like this:
sudo cu -l /dev/tty.usbmodem* -s 9600 --nostop --parity=none
The laptop I'm using is a 2007 MacBook Pro running OS X 10.8.4.
From the Teensy loader:
Verbose Information
00:40:50: Teensy Loader 1.15-rc1, begin program
00:40:50: File "Morse.cpp.hex". 33968 bytes, 26% used
00:40:50: Listening for remote control on port 3149
00:40:50: initialized, showing main window
00:40:50: remote connection opened
00:40:50: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
00:40:50: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
00:40:50: remote cmd: "file:Morse.cpp.hex"
00:40:50: remote cmd: "status"
00:40:50: status data sent
00:40:50: remote cmd: "auto:on"
00:40:50: remote connection closed
00:40:51: HID/macos: no devices found
07:40:57: remote connection opened
07:40:57: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
07:40:57: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
07:40:57: remote cmd: "file:Morse.cpp.hex"
07:40:57: File "Morse.cpp.hex". 33968 bytes, 26% used
07:40:57: remote cmd: "status"
07:40:57: status data sent
07:40:57: remote connection closed
07:40:58: remote cmd: "status"
07:40:58: status data sent
07:40:59: remote cmd: "status"
07:40:59: status data sent
07:41:00: remote cmd: "status"
07:41:00: status data sent
07:41:01: remote cmd: "status"
07:41:01: status data sent
07:41:02: remote cmd: "status"
07:41:02: status data sent
07:41:03: remote connection closed
07:41:17: file changed
07:41:17: File "Morse.cpp.hex". 33968 bytes, 26% used
07:41:17: remote connection opened
07:41:17: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
07:41:17: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
07:41:17: remote cmd: "file:Morse.cpp.hex"
07:41:17: remote cmd: "status"
07:41:17: status data sent
07:41:17: remote connection closed
07:41:18: remote connection opened
07:41:18: remote cmd: "status"
07:41:18: status data sent
07:41:18: Device came online, code_size = 131072
07:41:18: Board is: Teensy 3.0 (MK20DX128)
07:41:18: File "Morse.cpp.hex". 33968 bytes, 26% used
07:41:18: elf size appears to be 131072
07:41:18: elf binary data matches hex file
07:41:18: Code size from .elf file = 131072
07:41:18: begin operation
07:41:18: flash, block=0, bs=1024, auto=1
07:41:18: flash, block=1, bs=1024, auto=1
07:41:18: remote connection closed
07:41:18: flash, block=2, bs=1024, auto=1
07:41:18: flash, block=3, bs=1024, auto=1
07:41:18: flash, block=4, bs=1024, auto=1
07:41:18: flash, block=5, bs=1024, auto=1
07:41:18: flash, block=6, bs=1024, auto=1
07:41:18: flash, block=7, bs=1024, auto=1
07:41:18: flash, block=8, bs=1024, auto=1
07:41:18: HID/macos: waiting for device
07:41:18: flash, block=9, bs=1024, auto=1
07:41:18: flash, block=10, bs=1024, auto=1
07:41:19: HID/macos: waiting for device
07:41:19: flash, block=11, bs=1024, auto=1
07:41:19: flash, block=12, bs=1024, auto=1
07:41:19: flash, block=13, bs=1024, auto=1
07:41:19: flash, block=14, bs=1024, auto=1
07:41:19: flash, block=15, bs=1024, auto=1
07:41:19: flash, block=16, bs=1024, auto=1
07:41:19: flash, block=17, bs=1024, auto=1
07:41:19: flash, block=18, bs=1024, auto=1
07:41:19: flash, block=19, bs=1024, auto=1
07:41:19: flash, block=20, bs=1024, auto=1
07:41:19: flash, block=21, bs=1024, auto=1
07:41:19: flash, block=22, bs=1024, auto=1
07:41:19: flash, block=23, bs=1024, auto=1
07:41:19: flash, block=24, bs=1024, auto=1
07:41:19: flash, block=25, bs=1024, auto=1
07:41:19: flash, block=26, bs=1024, auto=1
07:41:19: flash, block=27, bs=1024, auto=1
07:41:19: flash, block=28, bs=1024, auto=1
07:41:19: flash, block=29, bs=1024, auto=1
07:41:19: flash, block=30, bs=1024, auto=1
07:41:19: flash, block=31, bs=1024, auto=1
07:41:19: flash, block=32, bs=1024, auto=1
07:41:19: flash, block=33, bs=1024, auto=1
07:41:19: sending reboot
07:41:19: begin wait_until_offline
07:41:19: HID/macos: status: ok
07:41:19: offline, waited 9
07:41:19: end operation
07:41:19: redraw timer set, image 14 to show for 1200 ms
07:41:19: HID/macos: number of devices found = 0
07:41:19: HID/macos: no devices found (empty set)
07:41:20: redraw, image 9
17:30:28: remote connection opened
17:30:28: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
17:30:28: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
17:30:28: remote cmd: "file:Morse.cpp.hex"
17:30:28: File "Morse.cpp.hex". 34512 bytes, 26% used
17:30:28: remote cmd: "status"
17:30:28: status data sent
17:30:28: remote connection closed
17:30:29: remote cmd: "status"
17:30:29: status data sent
17:30:29: Device came online, code_size = 131072
17:30:29: Board is: Teensy 3.0 (MK20DX128)
17:30:29: File "Morse.cpp.hex". 34512 bytes, 26% used
17:30:29: elf size appears to be 131072
17:30:29: elf binary data matches hex file
17:30:29: Code size from .elf file = 131072
17:30:29: begin operation
17:30:29: flash, block=0, bs=1024, auto=1
17:30:29: flash, block=1, bs=1024, auto=1
17:30:29: remote connection closed
17:30:29: flash, block=2, bs=1024, auto=1
17:30:29: flash, block=3, bs=1024, auto=1
17:30:29: flash, block=4, bs=1024, auto=1
17:30:29: flash, block=5, bs=1024, auto=1
17:30:29: flash, block=6, bs=1024, auto=1
17:30:29: flash, block=7, bs=1024, auto=1
17:30:29: flash, block=8, bs=1024, auto=1
17:30:29: flash, block=9, bs=1024, auto=1
17:30:29: flash, block=10, bs=1024, auto=1
17:30:29: flash, block=11, bs=1024, auto=1
17:30:29: flash, block=12, bs=1024, auto=1
17:30:29: flash, block=13, bs=1024, auto=1
17:30:29: HID/macos: waiting for device
17:30:29: flash, block=14, bs=1024, auto=1
17:30:29: flash, block=15, bs=1024, auto=1
17:30:29: flash, block=16, bs=1024, auto=1
17:30:29: flash, block=17, bs=1024, auto=1
17:30:29: flash, block=18, bs=1024, auto=1
17:30:29: flash, block=19, bs=1024, auto=1
17:30:29: flash, block=20, bs=1024, auto=1
17:30:29: flash, block=21, bs=1024, auto=1
17:30:29: flash, block=22, bs=1024, auto=1
17:30:29: flash, block=23, bs=1024, auto=1
17:30:29: flash, block=24, bs=1024, auto=1
17:30:29: flash, block=25, bs=1024, auto=1
17:30:29: flash, block=26, bs=1024, auto=1
17:30:29: flash, block=27, bs=1024, auto=1
17:30:29: flash, block=28, bs=1024, auto=1
17:30:29: flash, block=29, bs=1024, auto=1
17:30:29: flash, block=30, bs=1024, auto=1
17:30:29: flash, block=31, bs=1024, auto=1
17:30:29: flash, block=32, bs=1024, auto=1
17:30:29: flash, block=33, bs=1024, auto=1
17:30:29: sending reboot
17:30:29: begin wait_until_offline
17:30:29: HID/macos: status: ok
17:30:29: offline, waited 4
17:30:29: end operation
17:30:29: redraw timer set, image 14 to show for 1200 ms
17:30:30: HID/macos: number of devices found = 0
17:30:30: HID/macos: no devices found (empty set)
17:30:31: redraw, image 9
17:34:44: remote connection opened
17:34:44: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
17:34:44: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
17:34:44: remote cmd: "file:Morse.cpp.hex"
17:34:44: File "Morse.cpp.hex". 34528 bytes, 26% used
17:34:44: remote cmd: "status"
17:34:44: status data sent
17:34:44: remote connection closed
17:47:30: remote connection opened
17:47:30: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
17:47:30: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
17:47:30: remote cmd: "file:Morse.cpp.hex"
17:47:30: File "Morse.cpp.hex". 34776 bytes, 27% used
17:47:30: remote cmd: "status"
17:47:30: status data sent
17:47:30: remote connection closed
17:47:30: Device came online, code_size = 131072
17:47:30: Board is: Teensy 3.0 (MK20DX128)
17:47:30: elf size appears to be 131072
17:47:30: elf binary data matches hex file
17:47:30: Code size from .elf file = 131072
17:47:30: begin operation
17:47:30: flash, block=0, bs=1024, auto=1
17:47:31: remote connection closed
17:47:31: flash, block=1, bs=1024, auto=1
17:47:31: HID/macos: waiting for device
17:47:31: flash, block=2, bs=1024, auto=1
17:47:31: flash, block=3, bs=1024, auto=1
17:47:31: flash, block=4, bs=1024, auto=1
17:47:31: flash, block=5, bs=1024, auto=1
17:47:31: flash, block=6, bs=1024, auto=1
17:47:31: flash, block=7, bs=1024, auto=1
17:47:31: flash, block=8, bs=1024, auto=1
17:47:31: flash, block=9, bs=1024, auto=1
17:47:31: flash, block=10, bs=1024, auto=1
17:47:31: flash, block=11, bs=1024, auto=1
17:47:31: flash, block=12, bs=1024, auto=1
17:47:31: flash, block=13, bs=1024, auto=1
17:47:31: flash, block=14, bs=1024, auto=1
17:47:31: flash, block=15, bs=1024, auto=1
17:47:31: flash, block=16, bs=1024, auto=1
17:47:31: flash, block=17, bs=1024, auto=1
17:47:31: flash, block=18, bs=1024, auto=1
17:47:31: flash, block=19, bs=1024, auto=1
17:47:31: flash, block=20, bs=1024, auto=1
17:47:31: flash, block=21, bs=1024, auto=1
17:47:31: flash, block=22, bs=1024, auto=1
17:47:31: flash, block=23, bs=1024, auto=1
17:47:31: flash, block=24, bs=1024, auto=1
17:47:31: flash, block=25, bs=1024, auto=1
17:47:31: flash, block=26, bs=1024, auto=1
17:47:31: flash, block=27, bs=1024, auto=1
17:47:31: flash, block=28, bs=1024, auto=1
17:47:31: flash, block=29, bs=1024, auto=1
17:47:31: flash, block=30, bs=1024, auto=1
17:47:31: flash, block=31, bs=1024, auto=1
17:47:31: flash, block=32, bs=1024, auto=1
17:47:31: flash, block=33, bs=1024, auto=1
17:47:31: sending reboot
17:47:31: begin wait_until_offline
17:47:31: HID/macos: status: ok
17:47:31: offline, waited 3
17:47:31: end operation
17:47:31: redraw timer set, image 14 to show for 1200 ms
17:47:31: HID/macos: number of devices found = 0
17:47:31: HID/macos: no devices found (empty set)
17:47:32: redraw, image 9
17:53:09: remote connection opened
17:53:09: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
17:53:09: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
17:53:09: remote cmd: "file:Morse.cpp.hex"
17:53:09: File "Morse.cpp.hex". 34760 bytes, 27% used
17:53:09: remote cmd: "status"
17:53:09: status data sent
17:53:09: remote connection closed
17:53:10: remote cmd: "status"
17:53:10: status data sent
17:53:10: Device came online, code_size = 131072
17:53:10: Board is: Teensy 3.0 (MK20DX128)
17:53:10: File "Morse.cpp.hex". 34760 bytes, 27% used
17:53:10: elf size appears to be 131072
17:53:10: elf binary data matches hex file
17:53:10: Code size from .elf file = 131072
17:53:10: begin operation
17:53:10: flash, block=0, bs=1024, auto=1
17:53:10: remote connection closed
17:53:10: flash, block=1, bs=1024, auto=1
17:53:10: flash, block=2, bs=1024, auto=1
17:53:10: flash, block=3, bs=1024, auto=1
17:53:10: HID/macos: waiting for device
17:53:10: flash, block=4, bs=1024, auto=1
17:53:10: flash, block=5, bs=1024, auto=1
17:53:10: flash, block=6, bs=1024, auto=1
17:53:10: flash, block=7, bs=1024, auto=1
17:53:10: flash, block=8, bs=1024, auto=1
17:53:10: flash, block=9, bs=1024, auto=1
17:53:10: flash, block=10, bs=1024, auto=1
17:53:10: flash, block=11, bs=1024, auto=1
17:53:10: flash, block=12, bs=1024, auto=1
17:53:10: flash, block=13, bs=1024, auto=1
17:53:10: flash, block=14, bs=1024, auto=1
17:53:10: flash, block=15, bs=1024, auto=1
17:53:10: flash, block=16, bs=1024, auto=1
17:53:10: flash, block=17, bs=1024, auto=1
17:53:10: flash, block=18, bs=1024, auto=1
17:53:10: flash, block=19, bs=1024, auto=1
17:53:10: flash, block=20, bs=1024, auto=1
17:53:10: flash, block=21, bs=1024, auto=1
17:53:10: flash, block=22, bs=1024, auto=1
17:53:10: flash, block=23, bs=1024, auto=1
17:53:10: flash, block=24, bs=1024, auto=1
17:53:10: flash, block=25, bs=1024, auto=1
17:53:10: flash, block=26, bs=1024, auto=1
17:53:10: flash, block=27, bs=1024, auto=1
17:53:10: flash, block=28, bs=1024, auto=1
17:53:10: flash, block=29, bs=1024, auto=1
17:53:10: flash, block=30, bs=1024, auto=1
17:53:10: flash, block=31, bs=1024, auto=1
17:53:10: flash, block=32, bs=1024, auto=1
17:53:11: flash, block=33, bs=1024, auto=1
17:53:11: sending reboot
17:53:11: begin wait_until_offline
17:53:11: HID/macos: status: ok
17:53:11: offline, waited 3
17:53:11: end operation
17:53:11: redraw timer set, image 14 to show for 1200 ms
17:53:11: HID/macos: number of devices found = 0
17:53:11: HID/macos: no devices found (empty set)
17:53:12: redraw, image 9
21:29:10: remote connection opened
21:29:10: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
21:29:10: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
21:29:10: remote cmd: "file:Morse.cpp.hex"
21:29:10: File "Morse.cpp.hex". 34760 bytes, 27% used
21:29:10: remote cmd: "status"
21:29:10: status data sent
21:29:10: remote connection closed
21:37:32: remote connection opened
21:37:32: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
21:37:32: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
21:37:32: remote cmd: "file:Morse.cpp.hex"
21:37:32: File "Morse.cpp.hex". 34760 bytes, 27% used
21:37:32: remote cmd: "status"
21:37:32: status data sent
21:37:32: remote connection closed
21:45:10: remote connection opened
21:45:10: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
21:45:10: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
21:45:10: remote cmd: "file:Morse.cpp.hex"
21:45:10: File "Morse.cpp.hex". 34776 bytes, 27% used
21:45:10: remote cmd: "status"
21:45:10: status data sent
21:45:10: remote connection closed
22:37:09: remote connection opened
22:37:09: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
22:37:09: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
22:37:09: remote cmd: "file:Morse.cpp.hex"
22:37:09: File "Morse.cpp.hex". 34768 bytes, 27% used
22:37:09: remote cmd: "status"
22:37:09: status data sent
22:37:09: remote connection closed
23:07:23: remote connection opened
23:07:23: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
23:07:23: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
23:07:23: remote cmd: "file:Morse.cpp.hex"
23:07:23: File "Morse.cpp.hex". 35088 bytes, 27% used
23:07:23: remote cmd: "status"
23:07:23: status data sent
23:07:23: remote connection closed
23:21:15: remote connection opened
23:21:15: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
23:21:15: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
23:21:15: remote cmd: "file:Morse.cpp.hex"
23:21:15: File "Morse.cpp.hex". 35088 bytes, 27% used
23:21:15: remote cmd: "status"
23:21:15: status data sent
23:21:15: remote connection closed
07:58:57: remote connection opened
07:58:57: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
07:58:57: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
07:58:57: remote cmd: "file:Morse.cpp.hex"
07:58:57: File "Morse.cpp.hex". 35064 bytes, 27% used
07:58:57: remote cmd: "status"
07:58:57: status data sent
07:58:57: remote connection closed
07:58:58: remote cmd: "status"
07:58:58: status data sent
07:58:59: remote cmd: "status"
07:58:59: status data sent
07:59:00: remote cmd: "status"
07:59:00: status data sent
07:59:01: remote cmd: "status"
07:59:01: status data sent
07:59:02: remote cmd: "status"
07:59:02: status data sent
07:59:02: remote connection closed
08:19:17: file changed
08:19:17: File "Morse.cpp.hex". 35296 bytes, 27% used
08:19:17: remote connection opened
08:19:17: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
08:19:17: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
08:19:17: remote cmd: "file:Morse.cpp.hex"
08:19:17: remote cmd: "status"
08:19:17: status data sent
08:19:17: remote connection closed
08:44:15: remote connection opened
08:44:15: file changed
08:44:15: File "Morse.cpp.hex". 35300 bytes, 27% used
08:44:15: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
08:44:15: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
08:44:15: remote cmd: "file:Morse.cpp.hex"
08:44:15: remote cmd: "status"
08:44:15: status data sent
08:44:15: remote connection closed
14:52:23: remote connection opened
14:52:24: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
14:52:24: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
14:52:24: remote cmd: "file:Morse.cpp.hex"
14:52:24: File "Morse.cpp.hex". 35300 bytes, 27% used
14:52:24: remote cmd: "status"
14:52:24: status data sent
14:52:24: remote connection closed
14:52:24: remote connection opened
14:52:25: remote cmd: "status"
14:52:25: status data sent
14:52:26: remote cmd: "status"
14:52:26: status data sent
14:52:27: remote cmd: "status"
14:52:27: status data sent
14:52:28: remote cmd: "status"
14:52:28: status data sent
14:52:29: remote cmd: "status"
14:52:29: status data sent
14:52:29: remote connection closed
14:52:38: remote connection opened
14:52:38: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
14:52:38: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
14:52:38: remote cmd: "file:Morse.cpp.hex"
14:52:38: File "Morse.cpp.hex". 35300 bytes, 27% used
14:52:38: remote cmd: "status"
14:52:38: status data sent
14:52:38: remote connection closed
14:52:39: remote cmd: "status"
14:52:39: status data sent
14:52:39: Device came online, code_size = 131072
14:52:39: Board is: Teensy 3.0 (MK20DX128)
14:52:39: File "Morse.cpp.hex". 35300 bytes, 27% used
14:52:39: elf size appears to be 131072
14:52:39: elf binary data matches hex file
14:52:39: Code size from .elf file = 131072
14:52:39: begin operation
14:52:39: flash, block=0, bs=1024, auto=1
14:52:39: HID/macos: waiting for device
14:52:39: remote connection closed
14:52:39: flash, block=1, bs=1024, auto=1
14:52:39: flash, block=2, bs=1024, auto=1
14:52:39: flash, block=3, bs=1024, auto=1
14:52:39: flash, block=4, bs=1024, auto=1
14:52:39: flash, block=5, bs=1024, auto=1
14:52:39: flash, block=6, bs=1024, auto=1
14:52:39: flash, block=7, bs=1024, auto=1
14:52:39: flash, block=8, bs=1024, auto=1
14:52:40: flash, block=9, bs=1024, auto=1
14:52:40: flash, block=10, bs=1024, auto=1
14:52:40: flash, block=11, bs=1024, auto=1
14:52:40: flash, block=12, bs=1024, auto=1
14:52:40: flash, block=13, bs=1024, auto=1
14:52:40: HID/macos: waiting for device
14:52:40: flash, block=14, bs=1024, auto=1
14:52:40: flash, block=15, bs=1024, auto=1
14:52:40: flash, block=16, bs=1024, auto=1
14:52:40: flash, block=17, bs=1024, auto=1
14:52:40: flash, block=18, bs=1024, auto=1
14:52:40: flash, block=19, bs=1024, auto=1
14:52:40: flash, block=20, bs=1024, auto=1
14:52:40: flash, block=21, bs=1024, auto=1
14:52:40: flash, block=22, bs=1024, auto=1
14:52:40: flash, block=23, bs=1024, auto=1
14:52:40: flash, block=24, bs=1024, auto=1
14:52:40: flash, block=25, bs=1024, auto=1
14:52:40: flash, block=26, bs=1024, auto=1
14:52:40: flash, block=27, bs=1024, auto=1
14:52:40: flash, block=28, bs=1024, auto=1
14:52:40: flash, block=29, bs=1024, auto=1
14:52:40: flash, block=30, bs=1024, auto=1
14:52:40: flash, block=31, bs=1024, auto=1
14:52:40: flash, block=32, bs=1024, auto=1
14:52:40: flash, block=33, bs=1024, auto=1
14:52:40: flash, block=34, bs=1024, auto=1
14:52:40: sending reboot
14:52:40: begin wait_until_offline
14:52:40: HID/macos: status: ok
14:52:42: offline failed, timeout after 50
14:52:42: reboot error
14:52:42: end operation
14:52:42: redraw timer set, image 13 to show for 4000 ms
14:52:46: redraw, image 10
14:53:00: remote connection opened
14:53:00: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
14:53:00: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
14:53:00: remote cmd: "file:Morse.cpp.hex"
14:53:00: File "Morse.cpp.hex". 35292 bytes, 27% used
14:53:00: remote cmd: "status"
14:53:00: status data sent
14:53:00: remote cmd: "auto:on"
14:53:00: elf size appears to be 131072
14:53:00: elf binary data matches hex file
14:53:00: Code size from .elf file = 131072
14:53:00: begin operation
14:53:00: remote connection closed
14:53:00: flash, block=0, bs=1024, auto=1
14:53:11: program: write error
14:53:11: remote cmd: "status"
14:53:11: status data sent
14:53:11: remote connection closed
14:53:11: end operation
14:53:11: redraw timer set, image 11 to show for 4000 ms
14:53:15: redraw, image 10
14:53:22: Open File event
14:53:57: Verbose Info event
Arduino Compiler Output
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/actions.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/actions.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/libmorse.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/libmorse.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mac.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mac.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/teensy3_morse_bsp.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/teensy3_morse_bsp.cpp.o
teensy3_morse_bsp.cpp: In function 'void check_read_dword()':
teensy3_morse_bsp.cpp:283:12: warning: unused variable 'e' [-Wunused-variable]
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/EEPROM/EEPROM.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Time/DateStrings.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Time/Time.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/analog.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/eeprom.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/keylayouts.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/math_helper.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -DTIME_T=1372517580 -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/mk20dx128.c -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mk20dx128.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/nonstd.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/pins_teensy.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial1.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial2.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial3.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/touch.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_desc.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_dev.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_joystick.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_keyboard.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_mem.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_midi.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_mouse.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_rawhid.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_seremu.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_serial.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/yield.c.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial1.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial2.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial3.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/IntervalTimer.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/IPAddress.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/main.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Print.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Stream.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Tone.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_flightsim.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_inst.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/WMath.cpp.o
Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/WString.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -Os -Wl,--gc-sections -mcpu=cortex-m4 -mthumb -T/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/mk20dx128.ld -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.elf /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/actions.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/libmorse.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mac.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/teensy3_morse_bsp.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/EEPROM/EEPROM.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Time/DateStrings.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Time/Time.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/analog.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/eeprom.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/keylayouts.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/math_helper.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mk20dx128.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/nonstd.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/pins_teensy.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial1.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial2.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial3.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/touch.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_desc.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_dev.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_joystick.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_keyboard.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_mem.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_midi.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_mouse.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_rawhid.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_seremu.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_serial.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/yield.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial1.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial2.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial3.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/IntervalTimer.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/IPAddress.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/main.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Print.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Stream.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Tone.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_flightsim.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_inst.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/WMath.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/WString.cpp.o -L/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp -larm_cortexM4l_math -lm
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.elf /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.eep
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.elf /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.hex
Binary sketch size: 33,152 bytes (of a 131,072 byte maximum)
Estimated memory use: 8,528 bytes (of a 16,384 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/teensy_reboot -v -v -v -v -pmk20dx128 -chalfkay -P/dev/tty.usbmodem12341 -b12000000 -D -Uflash:w:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.hex:i
teensy_reboot, verbose mode
trying port 3149
get_line: "Teensy Loader 1.15-rc1"
found Teensy Loader, version 1.15
send: status - at Sat Jun 29 14:53:00 2013
sent: status - at Sat Jun 29 14:53:00 2013
Error reading Teensy Loader status! (tr)This error should never happen. Please report this to paul@pjrc.com, hopefully with enough information to reproduce the problem so it can be understood and fixed!
Second try
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -DTIME_T=1372517751 -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/mk20dx128.c -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mk20dx128.c.o
trying port 3149
trying port 25981
trying port 6837
trying port 4782
trying port 5293
trying port 13752
Unable find Teensy Loader. Is the Teensy Loader application running?
trying port 3149
trying port 25981
trying port 6837
trying port 4782
trying port 5293
trying port 13752
PaulStoffregen
07-01-2013, 10:54 PM
There's definitely a known bug on the Mac. I'm working on it, but it's been slow going. I got diverted for several days to release 1.15, which fixed other issues on all platforms and added a couple small but important features.
Please post this on the mac errors (http://forum.pjrc.com/threads/23802-Macintosh-Teensy3-Errors) thread. It really helps me if all the Mac-related stuff is on a single thread. I will be reviewing everything on that thread as I work on the Mac code...
pictographer
07-02-2013, 03:01 AM
Done. And output converted to attachments. Thanks!
