View Full Version : CMSIS-DSP library supports
TronicLabs
08-08-2013, 11:50 PM
it would be possible to integrate this library, as it is now designed the Teensy 3.0?
sorry if the question is stupid, but it is because I am a beginner in this world.
el_supremo
08-09-2013, 01:50 AM
The ARM cortex M4 math library is installed as part of Teensyduino 1.15.
See my message #42 in this thread http://forum.pjrc.com/threads/14845 I posted some of the CMSIS examples which run on Teensy 3.
Pete
TronicLabs
08-09-2013, 11:26 AM
many thanks, I missed it
PaulStoffregen
08-09-2013, 12:24 PM
If you do anything with the math library, even pretty simple stuff, I hope you'll consider posting about it.
This library is pretty complex, so even pretty simple "how to" info might really help everyone who tries to use it.
manitou
07-19-2018, 12:03 AM
Here is an NXP link to some DSP benchmarks https://community.nxp.com/thread/327833 (fft, mult, sin, cos, fir, biquad cascade)
I ported some of the tests from the zip file and ran on T3.5@120mhz (IDE 1.8.5/1.42)
- arm_mult_f32 - 1.086 us ; // real float32 8
- arm_mult_f32 - 4.852 us ; // real float32 64
- arm_mult_f32 - 17.704 us ; // real float32 256
- arm_mult_f32 - 69.027 us ; // real float32 1024
- arm_mult_q31 - 1.671 us ; // real q31 8
- arm_mult_q31 - 6.891 us ; // real q31 64
- arm_mult_q31 - 24.553 us ; // real q31 256
- arm_mult_q31 - 95.128 us ; // real q31 1024
- arm_mult_q15 - 1.086 us ; // real q15 8
- arm_mult_q15 - 5.303 us ; // real q15 64
- arm_mult_q15 - 19.729 us ; // real q15 256
- arm_mult_q15 - 77.460 us ; // real q15 1024
- arm_sin_cos_f32 - 0.579 us ; // real float32
- arm_sin_cos_q31 - 0.671 us ; // real q31_t
- arm_cfft_radix2_q15 - 54.8 us ; // real q15_t 64
- arm_cfft_radix2_q15 - 257.0 us ; // real q15_t 256
- arm_cfft_radix2_q15 - 1169.7 us ; // real q15_t 1024
- arm_cfft_radix4_q15 - 34.5 us ; // real q15_t 64
- arm_cfft_radix4_q15 - 166.5 us ; // real q15_t 256
- arm_cfft_radix4_q15 - 784.7 us ; // real q15_t 1024
- arm_cfft_radix2_q31 - 102.6 us ; // real q31_t 64
- arm_cfft_radix2_q31 - 516.1 us ; // real q31_t 256
- arm_cfft_radix2_q31 - 2489.1 us ; // real q31_t 1024
- arm_cfft_radix4_q31 - 73.6 us ; // real q31_t 64
- arm_cfft_radix4_q31 - 390.8 us ; // real q31_t 256
- arm_cfft_radix4_q31 - 1947.9 us ; // real q31_t 1024
- arm_cfft_radix2_f32 - 71.1 us ; // real float32_t 64
- arm_cfft_radix2_f32 - 361.2 us ; // real float32_t 256
- arm_cfft_radix2_f32 - 1710.7 us ; // real float32_t 1024
- arm_cfft_radix4_f32 - 44.1 us ; // real float32_t 64
- arm_cfft_radix4_f32 - 220.9 us ; // real float32_t 256
- arm_cfft_radix4_f32 - 1079.8 us ; // real float32_t 1024
DD4WH
07-19-2018, 07:59 AM
thanks for your tests!
it seems the thread and the link is very old and relates to a very old version of CMSIS, e.g. some/most of the functions are deprecated now and have been superseded by new functions (e.g. arm_cfft_f32 (https://www.keil.com/pack/doc/CMSIS/DSP/html/group__ComplexFFT.html#gade0f9c4ff157b6b9c72a1eafd 86ebf80)).
There are (much?) faster and more accurate versions of CMSIS available now, which have been used on the Teensy, Jan has a detailed description on how to use it:
https://forum.pjrc.com/threads/40590-Teensy-Convolution-SDR-(Software-Defined-Radio)?p=129081&viewfull=1#post129081
All the best,
Frank DD4WH
manitou
07-19-2018, 11:17 AM
Tests were run with latest IDE 1.8.5/1.42. The arm_math.h for current IDE appears to be V1.1.0
DD4WH
07-19-2018, 11:34 AM
Yes, you are right, the recent IDE contains a very old version of CMSIS (and thus arm_math.h).
Therefore I provided the link to a way how to use a newer version which provides faster (and more accurate) algorithms, eg. for FFTs.
manitou
07-19-2018, 03:50 PM
I see there is now a version 5 https://github.com/ARM-software/CMSIS_5
Do your instructions for updating teensy core CMSIS includes/libs apply to version 5 as well?
DD4WH
07-19-2018, 03:52 PM
No, they only apply to the version given.
But there was a recent post (a few weeks ago, if I remember correctly) of somebody succesfully updating to version 5 by only editing one or two more lines. Unfortunately I could not find it by a forum search . . .
DD4WH
07-19-2018, 03:57 PM
found it:
https://forum.pjrc.com/threads/44570-Request-update-CMSIS-DSP-(arm_math-h)?p=182720&viewfull=1#post182720
(https://forum.pjrc.com/threads/44570-Request-update-CMSIS-DSP-(arm_math-h)?p=182720&viewfull=1#post182720)
I personally have succesfully used v4.5, but not version 5, so experiment yourself :-)
manitou
07-20-2018, 12:18 PM
Using the same benchmark (deprecated functions), and upgrading to v4.5 https://github.com/ARM-software/CMSIS, functions are faster
T3.5@120mhz arm_math.h v1.4.5
- arm_mult_f32 - 0.919 us ; // real float32 8
- arm_mult_f32 - 5.248 us ; // real float32 64
- arm_mult_f32 - 20.090 us ; // real float32 256
- arm_mult_f32 - 79.456 us ; // real float32 1024
- arm_mult_q31 - 1.187 us ; // real q31 8
- arm_mult_q31 - 5.984 us ; // real q31 64
- arm_mult_q31 - 22.431 us ; // real q31 256
- arm_mult_q31 - 88.219 us ; // real q31 1024
- arm_mult_q15 - 5.179 us ; // real q15 64
- arm_mult_q15 - 19.215 us ; // real q15 256
- arm_mult_q15 - 75.363 us ; // real q15 1024
- arm_sin_cos_f32 - 1.337 us ; // real float32
- arm_sin_cos_q31 - 2.506 us ; // real q31_t
- arm_cfft_radix2_q15 - 46.0 us ; // real q15_t 64
- arm_cfft_radix2_q15 - 214.9 us ; // real q15_t 256
- arm_cfft_radix2_q15 - 982.8 us ; // real q15_t 1024
- arm_cfft_radix4_q15 - 27.0 us ; // real q15_t 64
- arm_cfft_radix4_q15 - 136.4 us ; // real q15_t 256
- arm_cfft_radix4_q15 - 668.6 us ; // real q15_t 1024
- arm_cfft_radix2_q31 - 106.6 us ; // real q31_t 64
- arm_cfft_radix2_q31 - 542.2 us ; // real q31_t 256
- arm_cfft_radix2_q31 - 2643.6 us ; // real q31_t 1024
- arm_cfft_radix4_q31 - 58.9 us ; // real q31_t 64
- arm_cfft_radix4_q31 - 316.2 us ; // real q31_t 256
- arm_cfft_radix4_q31 - 1585.1 us ; // real q31_t 1024
- arm_cfft_radix2_f32 - 57.8 us ; // real float32_t 64
- arm_cfft_radix2_f32 - 291.5 us ; // real float32_t 256
- arm_cfft_radix2_f32 - 1417.6 us ; // real float32_t 1024
- arm_cfft_radix4_f32 - 37.6 us ; // real float32_t 64
- arm_cfft_radix4_f32 - 186.1 us ; // real float32_t 256
- arm_cfft_radix4_f32 - 893.1 us ; // real float32_t 1024
For V5.3 I had to ifdef out all of hardware/teensy/avr/cores/teensy3/core_cm4_simd.h for compile to work
T3.5@120mhz arm_math.h V1.5.3
- arm_mult_f32 - 20.089 us ; // real float32 256
- arm_mult_f32 - 79.454 us ; // real float32 1024
- arm_mult_q31 - 1.338 us ; // real q31 8
- arm_mult_q31 - 6.140 us ; // real q31 64
- arm_mult_q31 - 22.564 us ; // real q31 256
- arm_mult_q31 - 88.342 us ; // real q31 1024
- arm_mult_q15 - 0.944 us ; // real q15 8
- arm_mult_q15 - 4.922 us ; // real q15 64
- arm_mult_q15 - 18.558 us ; // real q15 256
- arm_mult_q15 - 73.103 us ; // real q15 1024
- arm_sin_cos_f32 - 1.254 us ; // real float32
- arm_cfft_radix2_q15 - 45.3 us ; // real q15_t 64
- arm_cfft_radix2_q15 - 213.7 us ; // real q15_t 256
- arm_cfft_radix2_q15 - 988.5 us ; // real q15_t 1024
- arm_cfft_radix4_q15 - 27.2 us ; // real q15_t 64
- arm_cfft_radix4_q15 - 136.8 us ; // real q15_t 256
- arm_cfft_radix4_q15 - 658.5 us ; // real q15_t 1024
- arm_cfft_radix2_q31 - 117.3 us ; // real q31_t 64
- arm_cfft_radix2_q31 - 606.3 us ; // real q31_t 256
- arm_cfft_radix2_q31 - 2985.4 us ; // real q31_t 1024
- arm_cfft_radix4_q31 - 58.4 us ; // real q31_t 64
- arm_cfft_radix4_q31 - 314.3 us ; // real q31_t 256
- arm_cfft_radix4_q31 - 1577.9 us ; // real q31_t 1024
- arm_cfft_radix2_f32 - 57.9 us ; // real float32_t 64
- arm_cfft_radix2_f32 - 291.6 us ; // real float32_t 256
- arm_cfft_radix2_f32 - 1417.7 us ; // real float32_t 1024
- arm_cfft_radix4_f32 - 39.0 us ; // real float32_t 64
- arm_cfft_radix4_f32 - 192.5 us ; // real float32_t 256
- arm_cfft_radix4_f32 - 919.5 us ; // real float32_t 1024
Some fft's are slower than 4.5
Comparative anatomy
The Teensy audio library uses arm_cfft_radix4_q15(). So here are some performance comparisons.
q15 radix 4 1024 FFT, MCU @120MHz
MCU microseconds REVERSEBITS arm_math.h
T3.5 784.7 860.4 1.1.0 GCC Faster
668.6 726.9 1.4.5
658.5 717.0 1.5.3
K64F 635.7 691.6 1.4.5 mbed ARM CC, new arm_cfft_q15() 640.4 us
MK70F 755.0 1.1.0? NXP DSP benchmark, IAR CC
willie.from.texas
07-25-2018, 04:11 AM
Good comparison but instead recommend running arm_cfft_f32 for Version 5 .3 as the radix2 and radix4 algorithms have been deprecated.
willie.from.texas
07-30-2018, 12:44 AM
Here's the Version 5.3 performance for the floating point real and complex fft routines using the Teensy 3.6. The forward and inverse rfft (real-fft) uses arm_rfft_fast_f32. The forward and inverse cfft (complex-fft) uses arm_cfft_f32.
It is difficult to directly compare these results with the performance from Manitou above because they are obtained using a Teensy 3.6 @ 180 MHz. Assuming 1417.7 us is for a 1024 point forward transform using arm_cfft_radix4_f32, Version 5.3 is approximately 1.6 times faster when using the latest algorithms and taking the differences in clock speeds into account.
