I'm working on a project with Teensy 2.0. In Summery, One µC need to Monitor an Application ( 4 other Teensy's + communication protocol ) and give feedback to the User on the PC via USB, This works pretty fine using the Code library: http://www.pjrc.com/teensy/usb_serial.html
Additionally, the µC mentioned above needs to read commands (+ some parameters) from the User (again via USB) and process them, but without interrupting the monitoring Task, i.e. it should be able to read commands whenever the user send some, and not waiting for commands without monitoring the Application. Is this possible using the Code library on the main page?
Best regards,
Syrer
EDIT1: I think i should have posted this in the Project Guidance Forum , sorry about that
Best regards,
Syrer
