I recently purchased the teensy3.0 from Sparkfun. I use Ardunio and i wanted something with more speed and memory. I also wanted to get into ARM programming.
I just finished loading the updated blink program. This is so that i know that the board is alive.
But during that process I figured i did not understand the Teensy3.0 loading process very well.
Note: I have already installed the teensyduino software on my PC.
So i plugged in the teensy. The default LED blink program started running. My PC also found a virtual COM port. I selected the com port and Teensy3 in my Arduino (1.05). I used the teensy LED blink example and changed the blink rate. Clicked on upload. But i got a message at the end of the upload tries saying that i need to press the button on the board.
So i press the button. The LED goes OFF. Then PC says it is installing a new software. Then i try upload again. Now another window, teensyloader opened up and program got uploaded.
So my questions are :
1: Everytime i upload a new program should i first press the button on the board ? Or can i uload without pushing the button each time.
2: When teensyduino connects to the PC it first shows up as a Vcom port. When i press the button and Halfkay loads, what is teensy now emulating on the USB ?
3: Does the HalfKay bootloader reside on the ARM chip ?
4: I felt that uploading process took longer than my uno uploading. First the Ardunio uploading. Then teensyloader uploading. Is this normal or am i doing something wrong.
I would really appreciate any help in clearing my confusion.
