dave
[SOLVED]Teensy 3.0: USB interface dead?
Hi to everybody.
Since I cut the USB power from the battery power (as explained in this post) I have a really big issue with my Teensy 3.0.
It simply doesn t work.
Putting both power I can see the led blinking (because it was so in the last program I could upload), but I m no more able to communicate to the board.
Im using Linux (debian) and when I insert the USB cable into the PC I can see the board:
but in the serial folder I cannot find it anyway:
so I cannot connect to the /dev/ttyACM0 as requested by Teensyrduino.
Of course rebboting didnt help.
What could I do? What could I check?
Thanks
Hi to everybody.
wilhem@U-2:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 046d:c31c Logitech, Inc. Keyboard K120 for Business
Bus 002 Device 003: ID 046d:c05a Logitech, Inc. Optical Mouse M90
[B]Bus 002 Device 004: ID 16c0:0483 VOTI Teensyduino Serial[/B]
wilhem@U-2:~$ ls /dev/tty*
/dev/tty /dev/tty14 /dev/tty20 /dev/tty27 /dev/tty33 /dev/tty4 /dev/tty46 /dev/tty52 /dev/tty59 /dev/tty8
/dev/tty0 /dev/tty15 /dev/tty21 /dev/tty28 /dev/tty34 /dev/tty40 /dev/tty47 /dev/tty53 /dev/tty6 /dev/tty9
/dev/tty1 /dev/tty16 /dev/tty22 /dev/tty29 /dev/tty35 /dev/tty41 /dev/tty48 /dev/tty54 /dev/tty60 /dev/ttyS0
/dev/tty10 /dev/tty17 /dev/tty23 /dev/tty3 /dev/tty36 /dev/tty42 /dev/tty49 /dev/tty55 /dev/tty61 /dev/ttyS1
/dev/tty11 /dev/tty18 /dev/tty24 /dev/tty30 /dev/tty37 /dev/tty43 /dev/tty5 /dev/tty56 /dev/tty62 /dev/ttyS2
/dev/tty12 /dev/tty19 /dev/tty25 /dev/tty31 /dev/tty38 /dev/tty44 /dev/tty50 /dev/tty57 /dev/tty63 /dev/ttyS3
/dev/tty13 /dev/tty2 /dev/tty26 /dev/tty32 /dev/tty39 /dev/tty45 /dev/tty51 /dev/tty58 /dev/tty7
Thanks
