Onboard Teensy 3.0 Compiler/Interpreter
simcop2387
Is anyone aware of anyone building any kind of scripting system on top of a teensy 3.0? I'm looking to load small user programs over either sd cards or wifi and wondering if someone has already built one that'd be easy to shanghai. If not i'm likely to try to build a subset of GLSL (it's all for scripting LED strings at run-time) or something similar.
http://www.freaklabs.org/index.php/Tutorials/Software/Tutorial-Using-CmdArduino.html
:cool:
This is the demo sketch for the command line interface
by FreakLabs. It's a simple command line interface
where you can define your own commands and pass arguments
to them.
//#include <Cmd.h>
#include <stdint.h>
#include <avr/pgmspace.h>
#define MAX_MSG_SIZE 60
// command line structure
typedef struct _cmd_t
char *cmd;
void (*func)(int argc, char **argv);
struct _cmd_t *next;
} cmd_t;
// Function declares
void cmdInit(uint32_t speed);
void cmdPoll();
void cmdAdd(char *name, void (*func)(int argc, char **argv));
uint32_t cmdStr2Num(char *str, uint8_t base);
// command line message buffer and pointer
static uint8_t msg[MAX_MSG_SIZE];
static uint8_t *msg_ptr;
// linked list for command table
static cmd_t *cmd_tbl_list, *cmd_tbl;
// text strings for command prompt (stored in flash)
//const char cmd_banner[] PROGMEM = "*************** CMD *******************";
//const char cmd_prompt[] PROGMEM = "CMD >> ";
//const char cmd_unrecog[] PROGMEM = "CMD: Command not recognized.";
const char cmd_unrecog[] = "CMD: Command not recognized.";
// init the command line and set it for a speed of 57600
cmdInit(57600);
cmdAdd("hello", hello);
// add the commands to the command table. These functions must
// already exist in the sketch. See the functions below.
// The functions need to have the format:
// void func_name(int arg_cnt, char **args)
// arg_cnt is the number of arguments typed into the command line
// args is a list of argument strings that were typed into the command line
cmdPoll();
// Print "hello world" when called from the command line.
// Usage: At the command line, type:
// hello
// That's it.
void hello(int arg_cnt, char **args)
Serial.println("Hello world.");
/* Functions */
Generate the main command prompt
void cmd_display()
char buf[50];
//strcpy_P(buf, cmd_banner);
//Serial.println(buf);
Serial.println (F("*************** CMD *******************"));
//strcpy_P(buf, cmd_prompt);
//Serial.print(buf);
Serial.print (F("CMD >> "));
Parse the command line. This function tokenizes the command input, then
searches for the command table entry associated with the commmand. Once found,
it will jump to the corresponding function.
void cmd_parse(char *cmd)
uint8_t argc, i = 0;
char *argv[30];
char buf[50];
cmd_t *cmd_entry;
fflush(stdout);
// parse the command line statement and break it up into space-delimited
// strings. the array of strings will be saved in the argv array.
argv = strtok(cmd, " ");
do
argv[++i] = strtok(NULL, " ");
} while ((i < 30) && (argv != NULL));
// save off the number of arguments for the particular command.
argc = i;
// parse the command table for valid command. used argv[0] which is the
// actual command name typed in at the prompt
for (cmd_entry = cmd_tbl; cmd_entry != NULL; cmd_entry = cmd_entry->next)
if (!strcmp(argv[0], cmd_entry->cmd))
cmd_entry->func(argc, argv);
cmd_display();
return;
// command not recognized. print message and re-generate prompt.
strcpy_P(buf, cmd_unrecog);
cmd_display();
This function processes the individual characters typed into the command
prompt. It saves them off into the message buffer unless its a "backspace"
or "enter" key.
void cmd_handler()
char c = Serial.read();
switch (c)
case '\r':
// terminate the msg and reset the msg ptr. then send
// it to the handler for processing.
*msg_ptr = '\0';
Serial.print("\r\n");
cmd_parse((char *)msg);
msg_ptr = msg;
case '\b':
// backspace
Serial.print(c);
if (msg_ptr > msg)
msg_ptr--;
default:
// normal character entered. add it to the buffer
Serial.print(c);
*msg_ptr++ = c;
This function should be set inside the main loop. It needs to be called
constantly to check if there is any available input at the command prompt.
void cmdPoll()
while (Serial.available())
cmd_handler();
Initialize the command line interface. This sets the terminal speed and
and initializes things.
// init the msg ptr
msg_ptr = msg;
// init the command table
cmd_tbl_list = NULL;
// set the serial speed
Serial.begin(speed);
Add a command to the command table. The commands should be added in
at the setup() portion of the sketch.
// alloc memory for command struct
cmd_tbl = (cmd_t *)malloc(sizeof(cmd_t));
// alloc memory for command name
char *cmd_name = (char *)malloc(strlen(name)+1);
// copy command name
strcpy(cmd_name, name);
// terminate the command name
cmd_name[strlen(name)] = '\0';
// fill out structure
cmd_tbl->cmd = cmd_name;
cmd_tbl->func = func;
cmd_tbl->next = cmd_tbl_list;
cmd_tbl_list = cmd_tbl;
Convert a string to a number. The base must be specified, ie: "32" is a
different value in base 10 (decimal) and base 16 (hexadecimal).
return strtol(str, NULL, base);
/* end of file */
