View Full Version : Footsy - Teensy 2 based MIDI foot pedal controller
oddson
11-19-2013, 07:12 AM
Teensy-based MIDI foot-controller system -- just add sustain and expression pedals.
1117
Physical build consists of nothing but a Teensy 2, some 1/4" sockets, a USB cable and a polystyrene enclosure.
Here's a screenshot of the SysEx CC assign system (built with FlowStone (http://www.dsprobotics.com/) [forum (http://www.dsprobotics.com/support/viewtopic.php?f=3&t=1859)])
1115
It sends a small (16 byte) sysex message to configure the box -- only nine bytes are program data, the rest is to make sure it's the intended message.
(I used the private-use (non-commercial) sysex ID '7D' with an added four bytes as a 'key'.)
The code also sends back three bytes as an acknowledge message.
Code - fragments and ideas stolen liberally from all over but especially Knobber (http://www.vguitarforums.com/smf/index.php?topic=8532.0)
#include <Bounce.h>
#include <EEPROM.h>
const int thrshld = 7; // threshold for when change in voltage updates CC on analog pins
const int delayL = 5; // > delay can reduce number of MIDI msgs - can be good or bad??
// higher delay likely advantage if using lower threshold to limit repeats at same CC
int chnl; // MIDI channel
int v0,v1;// analog values for volage from dividers
int v0L, v1L;// lagged voltage values - last time cc was recalc'd
int v0D = 10,v1D = 10; // delta values - current - lag; force cc to calc on init
int toggled[3] = {false,false,false}; // toggle indicates when toggle behavior in effect
int mem[14]={1,4,7,64,0,65,0,66,0};// an array of sysEx bytes, + defaults until EEPROM is loaded
Bounce button[3] = {Bounce(0, 5),Bounce(1, 5),Bounce(2, 5)}; // init 'bounce' for 3 buttons
Serial.begin(31250);
pinMode(0, INPUT_PULLUP); // set up three digital pins
pinMode(1, INPUT_PULLUP); // with PULLUPs
pinMode(2, INPUT_PULLUP); //
if (EEPROM.read(0)>0 && EEPROM.read(0)<17){ // EEPROM @ 0 is non-zer0 or not a viable MIDI channel
for (int i = 0; i <= 8; i++) { // read EEPROM for sysEx data
mem[i] = EEPROM.read(i);
delay(5); // give time for EEPROM read??
int chnl = mem[0];
// *************THE MAIN LOOP************
if(usbMIDI.read() && usbMIDI.getType() == 7) { //if MIDI is sysEx
doSysEx(); // look for CC change msg
getAnalogData(); // get/process analog pins
getDigitalData(); // get/process digital pins
delay(delayL);
//************ANALOG SECTION**************
void getAnalogData(){
v0 = analogRead(0);
v1 = analogRead(1);
if (v0D > thrshld) // if delta variable shows change past threshold - recalulate
usbMIDI.sendControlChange(mem[1], v0/8, chnl); // calculate CC for analog 1 and send
v0L = v0; // lag only on update
v0D = abs(v0L-v0);
if (v1D > thrshld)
usbMIDI.sendControlChange(mem[2], v1/8, chnl); // calculate CC for analog 2 and send
v1L = v1; // lag only on update
v1D = abs(v1L-v1);
//************DIGITAL SECTION**************
void getDigitalData(){
for (int i = 0; i < 3; i++){
button[i].update(); //update bounce object for each button
if (button[i].fallingEdge()) { // button press to ground
if (toggled[i] && mem[i * 2 + 4]==1){ // if toggled state and toggle behavoiour both true...
usbMIDI.sendControlChange(mem[i * 2 + 3], 0, chnl); // unlatch to OFF
toggled[i] = false ; // toggled to false for next time
else { // either latched and toggled==false or non-latched...
usbMIDI.sendControlChange(mem[i * 2 + 3],127, chnl); //...either way to to ON state
if(mem[i * 2 + 4]==1){
toggled[i] = true ; // but only change toggled state if in latched mode
if (button[i].risingEdge()) { // button release - pullup to HIGH
if (not(mem[i * 2 + 4]==1)){ // if non-latched
usbMIDI.sendControlChange(mem[i * 2 + 3], 0, chnl); // to to OFF
//************SYSEX SECTION**************
void doSysEx(){
byte *sysExBytes = usbMIDI.getSysExArray();
if (sysExBytes[0] == 0xf0
&& sysExBytes[15] == 0xf7
&& sysExBytes[1] == 0x7D // 7D is private use (non-commercial)
&& sysExBytes[2] == 0x4C // 4-byte 'key' - not really needed if via USB but why not!
&& sysExBytes[3] == 0x65
&& sysExBytes[4] == 0x69
&& sysExBytes[5] == 0x66){ // read and compare static bytes to ensure valid msg
for (int i = 0; i < 10; i++) {
EEPROM.write(i, sysExBytes[i+6]);
mem[i] = sysExBytes[i+6];
byte data[] = { 0xF0, 0x7D, 0xF7 }; // ACK msg - should be safe for any device even if listening for 7D
usbMIDI.sendSysEx(3, data); // SEND
for (int i = 0; i < 3; i++) {
toggled[i] = false; // for consistant behaviour, start in OFF position
MickMad
11-19-2013, 01:57 PM
Nice stuff! I always wanted to make my very own MIDI foot controller w/ a Teensy. I also love the idea of using sysex messages to configure the thing ;)
I don't know what do you use this for, but I'd love to have something like 10 heavy-duty footswitches on mine, I don't like the idea of plugging things together to actually use something. You know, you could easily hack a few footswitches and expression pedal inside a bigger box and you'll have a ready-to-use all-in-one foot controller ;) Keep up the good work :)
oddson
11-19-2013, 02:21 PM
The plan is to make one with many momentary switches built in and with proper MIDI in/out/through. But it would still have external expression connections and at least two external switches as sustain pedals are so nice to 'play' -- rather than when you want to latch on an effect.
This one was to get a build done quickly and cheaply. I love Teensy!:D
PaulStoffregen
11-19-2013, 04:33 PM
Nice looking build.
I'd like to show this on the Teensy Projects page. But an image at least 300 pixels wide is needed. Any chance you could post a higher res image?
oddson
11-19-2013, 05:23 PM
Nice looking build.
Thanks... :o Would look better if I could get three holes to line up! ;)
I'll post better photos shortly (took that one after midnight last night as I wanted to post something here in a hurry)...
Can you hold off for a week or so with adding it to your projects page until I can polish things a bit and to show the FlowStone part on their site?
And would you update with a link to my site (oddsonic.com (http://oddsonic.com)) once I have something on it there? (It's just a placeholder site for the domain name with some of my music on in right now.)
PaulStoffregen
11-19-2013, 05:54 PM
Sure, not a problem. Just post when you're ready.
oddson
11-21-2013, 06:43 AM
here are the photos for the project page and a link (http://www.dsprobotics.com/support/viewtopic.php?f=3&t=1859) to a thread on the CC software on the FlowStone site.
pianomarten
10-30-2014, 09:20 AM
Hi!
I am going to build one of theese. I have a Teensy 3.1 on its way but I have never programmed. So is it possible to get some help?
How do I start?
Can I download the program/ code?
What program do I need?
Is it possible to do this with a Mac? (I have both)
Best Regards/
Mårten
PaulStoffregen
10-30-2014, 11:15 AM
How do I start?
This tutorial is a pretty good starting point.
http://www.pjrc.com/teensy/tutorial.html
After you get Arduino + Teensyduino set up and you're able to upload the LED blink, perhaps open some of the examples, from File > Examples > Teensy > USB_MIDI. Even if those examples aren't exactly what you need, I'd highly recommend at least connecting a pushbutton and get it to send note-on & note-off messages to software on your Mac. It's always easier to begin a new project when you've got a solid working example as starting point.
Headroom
10-30-2014, 04:46 PM
The enclosure in the images posted earlier in this thread look like the small enclosures from Hammond MfG.
Just in case they are not, Hammond makes these nice aluminum Die Cast boxes spcifically for Stomp Boxes (http://www.hammondmfg.com/dwg_SBVer.htm).
Avaiable from Digikey and other sources. The smaller boxes cost about $10.
oddson
11-02-2014, 07:28 PM
Hi!
I am going to build one of these...The physical build is very simple. (@Headroom - It is a Hammond 1590B project box but --as mentioned in the initial post-- it's just Polystyrene as die-cast aluminum for EM shielding isn't needed for and non-audio project like this.)
I have a Teensy 3.1 on its way...I don't know if any changes to my code above are required for a teensy 3.x as I built mine with a 2.x.
...but I have never programmed. Hopefully you have the left-brain skills that makes programming make sense for you. Arduino programming is fairly straightforward but it's still programming. Take the time with Paul's tutorials before trying to move on.
So is it possible to get some help? There's a lot of help available here if you put in some effort. If there's something about my code you need help with I'd be happy to assist.
Is it possible to do this with a Mac?The Teensyduino software is available for the Mac but the Flowstone 'CC Assign Tool' applet referenced above works only on Windows. But you can skip it altogether and just use hard-coded CC parameters into your device or find another program to send MIDI Sysex to the device. It's just 16 bytes of Sysex data and there are lots of Mac programs that could do this part, although likely without a graphical user-interface for picking the parameters.
pianomarten
11-03-2014, 08:03 AM
Thanks for your answers. I have done the blink programming so I know it is working. I think I'll skip the sysex for now. I want to have only 2 foot pedals. One for changing patch in MainStage (cc04 or 03) and one for sustain pedal on cc64 can I do a program like these?
Is this totally wrong?
#include <Bounce.h>
const int channel = 1;
Bounce button0 = Bounce(0, 5);
Bounce button1 = Bounce(1, 5);
button0.update();
button1.update();
if (button0.fallingEdge()) {
usbMIDI.setHandleControlChange(03, 127, channel); //cc03
if (button1.fallingEdge()) {
usbMIDI.setHandleControlChange(64, 127, channel); //cc64
while (usbMIDI.read()) {
// ignore incoming messages
oddson
11-04-2014, 01:27 PM
Your going 'on' when switch goes off and you're not dealing with the rising edge... but you're not too far off from what I can see.
pianomarten
11-04-2014, 02:09 PM
I don't understand. Do I need the rising edge too? Like this:
if (button0.risingEdge()) {
usbMIDI.setHandleControlChange(03, 0, channel); //cc03
if (button1.risingEdge()) {
usbMIDI.setHandleControlChange(64, 0, channel); //cc64
...Or should i just change falling to rising?
Sorry for hi-jacking your thread.
oddson
11-05-2014, 02:02 AM
Honestly I'm not too sure... I was barely competent at this when I made it a year or more ago but (unless I'm badly mistaken) you need something to send back an 'off' state when you let up on the pedal. That's assuming you're making momentary switch like a sustain pedal and not a toggle switch. If a toggle switch then you can ignore the falling state and have it change on the rising but you have to keep track of what state it was in last.
But assuming you do want a sustain-type momentary switch then you need to send a zero value when the switch is 'off'. And if so I think the what you have above is correct but possibly backward...
Because the next complicating factor is that some switches are normally open and some normally closed. If it's normally closed then you want the falling state to represent the 'on' state (MIDI=127) and the rising 'off' (MIDI=0) which is what you appear to have above.
Anyone else care to help with this... I'd hate to be mis-remembering how this works. :confused:
oddson
11-08-2014, 10:07 PM
You were really close... although you did change the MIDI function name (setHandleControlChange?) which I didn't notice and caused me a bit of confusion when I got a compiler error with your code...
This worked for me:
#include <Bounce.h>
button0.update();
button1.update();
usbMIDI.sendControlChange(3, 127, channel); //cc03
usbMIDI.sendControlChange(64, 127, channel); //cc64
usbMIDI.sendControlChange(3, 0, channel); //cc03
usbMIDI.sendControlChange(64, 0, channel); //cc64
If your switches are normally closed just swap the zero and the 127 values.
oddson
04-04-2018, 05:24 PM
If anyone is trying to run the code from the initial post a change is required for the current version of Teensyduino where getType() return values have been changed to match those from the main Arduino midi libaray:
The number '7' needs to be replaced with 0xF7 or (preferably):
if(usbMIDI.read() && usbMIDI.getType() == usbMIDI.SystemExclusive ) {
Max_SNPP
09-05-2018, 01:10 PM
Hello,
For my first post on the forum, I only want to thanks a lot Oddson for sharing his project. I was very inspired on it, to realize two midifoot projects.I made a program on Max/msp to flash CC config via sysex.
I used Teensy LC with both.
I made one box with 12 expression pedals inputs and 4 footswitchs inputs and another one with 10 footswitchs and 7 expression pedals inputs.
I could provide teensy code and max/msp path if someone is interested.
Here a photo of one box:
http://www.pompehop.com/wp-content/uploads/2018/09/IMG_2986-e1536152488577.jpg
oddson
09-05-2018, 03:02 PM
That's a lot of expression pedals... how many feet do you have?
Max_SNPP
09-05-2018, 07:20 PM
It's not for me, I made it for an Octopus :)
