snoring_portal
I am trying to get the 2.8" LCD breakout board from adafruit to work with my teensy 3.0, but I am getting these errors during compiling. I am using the adafruit GFX and TFTLCD libraries required by the tutorial from adafruit. I have tried compiling this on Windows 7, Debian linux and Slacko Puppy linux, to no avail. It will, however, compile okay with other boards, like the Teensy 2.0 and Arduino Due.
Any help would be appreciated!
Edit: I guess I should mention that I am trying to run the graphicstest that comes with the adafruit code!
Arduino: 1.0.4 (Linux), Board: "Teensy 3.0"
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In constructor 'Adafruit_TFTLCD::Adafruit_TFTLCD(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:99:3: error: '_reset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:112:3: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:113:3: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:114:3: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:115:3: error: 'rdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:116:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:117:3: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:118:3: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:119:3: error: 'rdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::begin(uint16_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:293:5: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:293:5: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:307:5: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:307:5: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::reset()':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:325:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:325:3: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:327:3: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:327:3: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:328:3: error: 'rdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:328:3: error: 'rdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:335:6: error: '_reset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:343:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:344:3: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:344:3: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:346:30: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setAddrWindow(int, int, int, int)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:355:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:355:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:415:3: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setLR()':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:425:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:425:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:428:3: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::flood(uint16_t, uint32_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:439:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:439:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:440:3: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:440:3: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:445:3: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:9: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:9: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:9: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:20: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:20: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:20: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:31: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:31: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:31: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:42: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:42: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:457:42: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:9: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:9: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:9: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:20: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:20: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:20: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:31: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:31: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:31: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:42: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:42: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:458:42: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:463:7: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:463:7: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:463:7: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:464:7: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:464:7: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:464:7: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:479:3: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'virtual void Adafruit_TFTLCD::fillScreen(uint16_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:578:5: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:578:5: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'virtual void Adafruit_TFTLCD::drawPixel(int16_t, int16_t, uint16_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:599:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:599:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:636:5: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:636:5: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:636:31: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:639:3: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::pushColors(uint16_t*, uint8_t, boolean)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:649:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:649:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:651:5: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:651:5: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:655:3: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:655:3: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:663:3: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setRotation(uint8_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:672:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:672:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'uint16_t Adafruit_TFTLCD::readPixel(int16_t, int16_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:716:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:716:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:743:7: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:743:7: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:744:7: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:752:5: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:760:5: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:760:5: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:762:5: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:768:5: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'uint16_t Adafruit_TFTLCD::readID()':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:780:3: error: 'csPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:780:3: error: 'csPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:781:3: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:781:3: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:783:3: error: 'wrPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:783:3: error: 'wrPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:783:3: error: 'wrPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:785:3: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:789:3: error: 'csPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::write8(uint8_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:804:21: error: 'write8inline' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'uint8_t Adafruit_TFTLCD::read8fn()':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:811:21: error: 'read8inline' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setWriteDir()':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:818:21: error: 'setWriteDirInline' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setReadDir()':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:824:20: error: 'setReadDirInline' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::writeRegister8(uint8_t, uint8_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:830:3: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:830:3: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:830:3: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::writeRegister16(uint16_t, uint16_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:836:3: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:836:3: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:836:3: error: 'cdPinSet' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::writeRegisterPair(uint8_t, uint8_t, uint16_t)':
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:842:3: error: 'cdPort' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:842:3: error: 'cdPinUnset' was not declared in this scope
/root/sketchbook/libraries/Adafruit_TFTLCD/Adafruit_TFTLCD.cpp:842:3: error: 'cdPinSet' was not declared in this scope
