Thank you very much for the flight control plugins for teensie. I'm sure I'm doing something wrong here.
I can get the teensie++2.0 to load the sketch in Linux and display output to an LCD panel connected to the teensie, but the X-Plane plugin "show Communications" detects the teensie insert and remove from the usb, but no data flow. I have tried multiple examples from flight controls including the "blinktransponder" and "NavFrequency". (all work in win7, but not linux)
To debug if the teensie detected X-Plane plugin I used the following code:
I'm running Ubuntu 10.04 64bit all packages current, Kernel 2.6.32-53-generic, X-Plane 10.25, Arduino 1.0.5.
All tests here are on the same Dual Boot (win7, ubuntu) desktop. (teensie is NOT connected via an external usb HUB)
NOTE: after programming teensie in Linux and the plugin not working in Linux, the same teensie device works perfect on Windows7 install of X-Plane. Also I have removed AppArmor from Ubuntu, just in case.
NOTE2: The Linux plugin for 64bit detects the teensie insert and remove, the 32bit linux plugin shows nothing at all.
// the LED shows if X-Plane is running and plugin is enabled
if (FlightSim.isEnabled()) {
update_lcd(NavFrequencyHz);
update_lcd(-99999);
update_lcd(-99999);
