View Full Version : Simple Mutex and Lock classes
christoph
12-26-2013, 09:06 PM
I thought I might toss in my mutex and lock classes, which seem (!) to work quite well. There's certainly room for improvement.
mutex.h:
#ifndef _MUTEX_H_
#define _MUTEX_H_
#include <stdint.h>
#include <util/atomic.h>
/** CRTP for mutex classes.
This is an abstract mutex class. Classes that derive from this class are intended for use in
other templates, such as ScopedLock. I'm not really sure why I chose the CRTP for this, but I'm
somehow sure that there won't be many uses of polymorphic mutex containers and such, so it
shouldn't be a big deal.
template<typename impl>
class AbstractMutex
public:
/** Lock the mutex, blocking.
void lock(void){asChild().lock_impl();}
/** Try to lock the mutex, non-blocking.
\return true if the mutex could be locked (i.e. was not locked before), false otherwise.
bool tryLock(void){return asChild().tryLock_impl();}
/** Try to lock the mutex. Blocks until the mutex can be locked or until
a timeout occurs after the given number of milliseconds.
\return true if the mutex was not locked before or if the mutex could be locked within the timeout, false otherwise.
bool timedLock(const uint32_t& msTimeout) {return asChild().timedLock_impl(msTimeout);}
/** Get the locked state.
\return true if the mutex is locked.
bool locked() {return asChild().locked_impl();}
/** Unlock the mutex.
void unlock(void){asChild().unlock_impl();}
protected:
virtual void lock_impl() {while(!tryLock());}
virtual bool timedLock_impl(const uint32_t& msTimeout)
elapsedMillis elapsed;
bool acquired = false;
do
acquired = tryLock();
while((elapsed <= msTimeout) && (!acquired));
return acquired;
private:
impl& asChild(){return static_cast<impl&>(*this);}
/** A simple binary mutex.
class Mutex : public AbstractMutex<Mutex>
public:
Mutex() : m_locked(false) {}
virtual bool tryLock_impl()
ATOMIC_BLOCK(ATOMIC_RESTORESTATE)
if (!m_locked)
m_locked = true;
acquired = true;
return acquired;
virtual bool locked_impl() {return m_locked;}
virtual void unlock_impl()
m_locked = false;
protected:
volatile bool m_locked;
/** Used for tag dispatching in the constructor of ScopedLock.
struct try_lock_t { };
/** Thanks to:
http://stackoverflow.com/questions/20775285/how-to-properly-use-tag-dispatching-to-pick-a-constructor
constexpr try_lock_t try_lock = try_lock_t();
/** A scoped lock class that unlocks a mutex on desctruction if the lock could be acquired before.
template<typename MutexType>
class ScopedLock
public:
/** Blocking constructor that acquires the lock.
ScopedLock(MutexType& mtx) : m_mtx(mtx), m_acquired(true) {m_mtx.lock();}
/** Non-blocking constructor that tries to acquire the lock.
ScopedLock(MutexType& mtx, try_lock_t) : m_mtx(mtx) {m_acquired = m_mtx.tryLock();}
/** Constructor that tries to acquire the lock for the specified number of milliseconds
ScopedLock(MutexType& mtx, const uint32_t& msTimeout) : m_mtx(mtx) {m_acquired = m_mtx.timedLock(msTimeout);}
/** Acquire the lock, blocking.
void lock()
if(!owns())
m_mtx.lock();
m_acquired = true;
/** Try to acquire the lock, non-blocking
bool tryLock()
if (!owns())
return m_acquired;
/** Try to acquire the lock for the specified number of milliseconds
if(!owns())
return m_acquired;
/** Check if the lock has been acquired
bool owns() const {return m_acquired;}
/** Release the lock if it has been acquired before.
void release()
if(owns())
m_mtx.unlock();
m_acquired = false;
/** Destructor. Releases the lock if it was acquired before.
~ScopedLock() {release();}
private:
MutexType& m_mtx;
bool m_acquired;
#endif // _MUTEX_H_
Usage examples (without interrupts, so they don't demonstrate much):
#include <WProgram.h>
#include <mutex/mutex.h>
int main()
// Open a terminal, connect to virtual serial and press any key!
while(!Serial.available());
Mutex mtx;
Serial.print("locked: ");Serial.println(mtx.locked());
ScopedLock<Mutex> lock(mtx);
Serial.print("acquired: ");Serial.println(lock.owns());
Serial.print("---");
Serial.print("lock: ");Serial.println(lock.owns());
ScopedLock<Mutex> tryLock(mtx, try_lock);
Serial.print("tryLock: ");Serial.println(tryLock.owns());
ScopedLock<Mutex> timedLock(mtx, 1000);
Serial.print("timedLock: ");Serial.println(timedLock.owns());
pinMode(13, OUTPUT);
if(lock.owns())
digitalWriteFast(13, true);
lock.release();
tryLock.lock();
I need this to manage access to the SPI, because app code and DMA use it concurrently. There are certainly many similar scenarios.
Regards
Christoph
