Markus_L811
12-31-2013, 09:04 PM
Hello,
on my own I'm a huge fan of the Blink example. So I did my part on it and make it more comfortable for me, code below.
/* LED Blink, Teensyduino Tutorial #1
http://www.pjrc.com/teensy/tutorial.html
// Teensy 2.0 has the LED on pin 11
// Teensy++ 2.0 has the LED on pin 6
// Teensy 3.0 has the LED on pin 13
#if defined(__MK20DX128__) || defined(__MK20DX256__)
// Teensy 3.0 Teensy 3.1
#define ledPin 13
#elif defined (__AVR_ATmega32U4__)
// Teensy 2.0
#define ledPin 11
#elif defined(__AVR_AT90USB162__) || defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__)
// Teensy 1.0 Teensy 1.0++ Teensy 2.0++
#define ledPin 6
#else
#define ledPin 13
//const int ledPin = Pin;
int timing = 125;
// the setup() method runs once, when the sketch starts
// initialize the digital pin as an output.
pinMode(ledPin, OUTPUT);
// the loop() methor runs over and over again,
// as long as the board has power
digitalWrite(ledPin, HIGH); // set the LED on
delay(timing); // wait for a second
digitalWrite(ledPin, LOW); // set the LED off
So I tested it on Arduino IDE 1.0.5 with Teensyduino 1.18RC all works fine except for Teensy 1.0 there I get this:
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.5 (Windows 7), Board: "Teensy 1.0"
C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s: Assembler messages:
C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:198: Error: illegal opcode mul for mcu at90usb162
C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:203: Error: illegal opcode mul for mcu at90usb162
C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:207: Error: illegal opcode mul for mcu at90usb162
C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:211: Error: illegal opcode mul for mcu at90usb162
C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:237: Error: illegal opcode mul for mcu at90usb162
On Arduino IDE 1.0.4 with Teensy 1.14RC2 it compiled fine. So what did I do wrong?
#define ledPin 13
// Teensy 2.0
#define ledPin 11
#define ledPin 6
#else
#define ledPin 13
int timing = 125;
