I know you're probably working on a Teensy 3.1++ which breaks out all the pins on a longer board, but what I'd really like is one which breaks out most of the pins on a board that is the same size using 2mm pin headers.
A 2mm teensy would ideally be just a smidge longer and a smidge wider, with 18 pins along each side, and 7 pins between them on the end. This would break out all 10 digital pins which are on the pads underneath.
2mm pin headers, in addition to breaking out more pins along the edge, would also greatly reduce the stack height if you seat the board on top of another. I've been looking at ways to break those pins out on the underside of the board with a board of my own design that sits on top of the audio board and with the 2.54mm pin headers the stack ends up being over 15mm tall. And that's something I can no longer call Teensy. Or fit in my enclosures.
