Hi , I have a RA8875 based display board that i can't get to work with my Teensy 3.0. I'm using to what I know the latest Adafruit RA8875 and GFX libraries. What I definitely find strange is that the serial debug monitoring doesn't work ? The code sends to the serial console wether the RA8875 is found or not , but nothing is happening here ? The serial console is working with the hello world example ... so it does work ... So is there any reason why this code shouldn't work ?
Capacitive multitouch demo for 7" LCD connected to Arduino.
Written 15 February 2014 by Helge Langehaug.
Depends on RA8875 library from Adafruit.
Tested with ER-TFTM070-5 (LCD) from EastRising (bought from buydisplay.com)
Follow the LCD manual and set resistors and jumpers according to
4 wire SPI interface for RA8875.
Connect LCD SPI to Arduino UNO SPI(using ICSP pins)
Tested with R1-R3 open instead of 10Kohm as stated in manual.
RA8875 communication, connect:
TFTM070(40 pin) Arduino UNO pin Description
1,2 GND
3,4 VCC
5 10 SPI SELECT
6 ICSP_MISO SDO / SPI_MISO
7 ICSP_MOSI SDI / SPI_MOSI
8 ICSP_SCK CLK
33 2 CTP_INT touch data ready be read
from FT5x06 touch controller
34 A4 I2C for FT5x06 (preconfigured)
35 A5 I2C for FT5x06 (preconfigured)
12 (why?) 9 TFTM070 board is not stable if this pin is not connected.
Could be a soldering or wire fault on my board ??
The Adafruit library puts a reset pulse on that pin but
according to board pin 12 is not connected...
So this could be different on other boards...
To be examined.
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
#include "Wire.h"
#include "FT5x06.h"
// Arduino pin
#define RA8875_CS 10 // RA8875 chip select for ISP communication
#define RA8875_RESET 16 // Adafruit library puts a short low reset pulse at startup on this pin.
// Not relevant for TFTM070 according to doc.
#define CTP_INT 20 // touch data ready for read from FT5x06 touch controller
#define SERIAL_DEBUG_ENABLED true // set to true if you want debug info to serial port
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
FT5x06 cmt = FT5x06(CTP_INT);
void serialDebugOutput(int nr_of_touches, word *coordinates) {
for (byte i = 0; i < nr_of_touches; i++){
word x = coordinates[i * 2];
word y= coordinates[i * 2 + 1];
Serial.print("x");
Serial.print(i);
Serial.print("=");
Serial.print(x);
Serial.print(",");
Serial.print("y");
Serial.print(i);
Serial.print("=");
Serial.print(y);
Serial.print(" ");
void printRawRegisterValuesToSerial(byte *registers) {
// print raw register values
for (int i = 0;i < FT5206_NUMBER_OF_REGISTERS ; i++){
Serial.print(registers[i],HEX);
Serial.print(",");
Serial.println("");
Serial.println("Trying to initialize RA8875 though SPI");
if (!tft.begin(RA8875_800x480)) {
Serial.println("RA8875 Not Found!");
while (1);
Serial.println("Found RA8875");
//cmt.printInfo();
tft.displayOn(true);
tft.GPIOX(true); // Enable TFT - display enable tied to GPIOX
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft.PWM1out(255);
tft.fillScreen(RA8875_GREEN);
tft.textMode();
tft.textSetCursor(10, 10);
tft.textTransparent(RA8875_WHITE);
tft.textEnlarge(1);
tft.textWrite("Capacitive touch sensor demo. Touch me !");
cmt.init(SERIAL_DEBUG_ENABLED);
Serial.println("Setup done.");
word prev_coordinates[10]; // 5 pairs of x and y
byte nr_of_touches = 0;
byte registers[FT5206_NUMBER_OF_REGISTERS];
word coordinates[10];
byte prev_nr_of_touches = 0;
if (cmt.touched()){
cmt.getRegisterInfo(registers);
nr_of_touches = cmt.getTouchPositions(coordinates, registers);
prev_nr_of_touches = nr_of_touches;
if (SERIAL_DEBUG_ENABLED){
printRawRegisterValuesToSerial(registers);
serialDebugOutput(nr_of_touches, coordinates);
// remove previous touches on screen
for (int i = 0 ; i < prev_nr_of_touches; i++){
word x = prev_coordinates[i * 2];
word y = prev_coordinates[i * 2 + 1];
tft.fillCircle(x, y, 70, RA8875_GREEN);
// mark touches on screen
word y = coordinates[i * 2 + 1];
// Mark touches on screen
tft.fillCircle(x, y, 70, RA8875_BLUE);
tft.fillCircle(x, y, 50, RA8875_WHITE);
tft.fillCircle(x, y, 30, RA8875_WHITE);
delay(10);
memcpy(prev_coordinates, coordinates, 20);
