lowerstoford
ADXL193 Accelerometer 5v analog sensor with Teensy 3.1
Hi
This may be a stupid question, but I just need to check I understand the 5v Tolerance on the 3.1
I have a ADXL193 that i need to use with a 3.1, it has a analog output that is related to the input voltage
on the datasheet https://www.sparkfun.com/datasheets/Sensors/Accelerometer/ADXL193.pdf
it states it needs 3.5 to 6 volts and I was planning on running it on 5v.
Am i understanding the 5v tolerance correctly?
If all digital pins are 5v tolerant, can they be used to analogread a 5v signal?
i.e. if I power the ADXL193 with 5v and connect the output to pin 23, and read the analog signal. will the teensy be ok?
I will post the details of the complete project on another thread
Thanks in advance
Lee
Hi
Thanks in advance
Lee
