Hello All
First post.
My name is John Maher, and I tinker around with micros and small scale electronics as a hobby . I am a software engineer by trade, programming now mostly in
managed OO COBOL and C#, but have many years of coding in everything from binary using patch plugs , through assemblers, c, c++ etc.
Purchased a Teensy 3.1 a couple of weeks ago, and really enjoying it . Cracking little thing , and a nice thriving community here as well.
using teensyduino 1.18 .
I have already interfaced a touch LCD to it, and am busy going through the micros functionality , learning what it can and can't do ,
I am busy trying to get the comparator module working . I want to use it to detect an analog signal and measure the frequency as accurately as possible. The comparator seems ideal as it can trigger at a threshold and generate an interrupt.
The problem :
If I try and read or touch any of the comparator registers, e.g. CMP0_CR0, the Teensy locks up .
For example, taking the stock Serial Hello World example that comes with Teensyduino, I compile and run it, and it works.
If I add in a line that accesses any of yhr the CMP registers, it locks up.
Example
The freescale application notes state that CMP0_CR0 and CMP0_CR1 need setting to 0 first, then the rest of the setup follows . I cant get past initialising the control registers .
Any help or guidance is most appreciated.
Thanks for the help in advance.
Cheers
John
First post.
The problem :
Example
Serial.begin(38400);
delay(10000); // wait for my fingers to open the serial monitor.
Serial.println("Starting");
// CMP0_CR0=0; // either of these two lines will cause the teensy to lock up.
uint8_t var = CMP0_CR0; // CMP0_CR0 is defined as an 8 bit unsigned integer ( char) .
// if you try it with the ADC control register, it works.
//uint32_t var = ADC0_CFG1; // ADC0_CFG1 is defined as a uint32_t (unsigned long integer)
for( ; ; )
char buffer[30]={};
sprintf(buffer,"Hello World - value is %d",var);
Serial.println(buffer);
Cheers
John
