Yes, I can confirm this works.
I tested it just now, using a MacBook Pro running OS-X 10.7.5, with two Teensy 3.1s programmed with File > Examples > Teensy > USB_Keyboard > Buttons, and of course Tools > USB Type set to Keyboard + Mouse + Joystick while uploading that sketch to both of them.
With both connected to the MacBook, and the cursor in a terminal window, I tried touching a wire from GND to the nearby pins. Both are able to type "B1 press" and "B1 release", "B2 press" and "B2 release", etc. This test involved touching the pins on 1 board at a time.
As a final test, to make sure they can truly type at the same time, I put the two Teensys on a breadboard and wired the pin 0 signals together. Then I touched a wire between the pair of pin 0 signals and ground, so both Teensys would try to type at the same moment. The results are not perfect. Here's a screenshot:
Sometimes the 2 simultaneous keystrokes appear as 2 characters, but sometimes only 1 character.
Then I tried using two real USB keyboards. I was able to reproduce the problem where a character appears only once when pressed on both keyboards. It's takes quick finger action! You have to press and hold key on the first keyboard, then press and release the same key on the other keyboard while holding the first one down. It's tricky to do manually, because holding the key on the first keyboard pretty quickly causes auto-repeat. But it's definitely possible to get only a single character typed if one keyboard sends the key press and release entirely inside the time the other keyboard has the key pressed and not yet released.
Mac OS-X appears to be merging the keyboard input at the key-down & key-up level. This obviously isn't anything to do with Teensy, or Trinket, or any USB keyboard, but how Apple's HID driver is merging the data streams. It seems to merge all the key-down and key-up events into a single event stream, and then it turns that single stream into actual input characters.
With Teensy, or Trinket, or any real USB keyboard, if both try to send the exact same key at the same moment, and the timing happens to have one send the key-down event while the other has the key-down without having sent the corresponding key-up event, you'll get only 1 keystroke registered instead of two.
But other than that small timing caveat, 2 Teensy 3.1 definitely do work.
I have no idea why Trinket didn't work, but there are all sorts of USB compliance issues with software-emulated USB, so I'm not surprised is would have issues. In fact, it's pretty amazing that can work at all.
