ajnovember
Hi all, I'm working on a project with my Teensy 3.1 that uses touchRead() with conductive rubber bands as MIDI triggers. The rubber bands' touchRead() readings change when you stretch the bands, which is very exciting, so I'm trying to do use that reading to input into usbMIDI.sendPitchBend and am getting super inconsistent/erratic results. Basically I just want to know what are the useful/important input values for usbMIDI.sendPitchBend, ie. what are the max and min values, what happens when you go above or below them, what is 'center' (no pitch bend), is this pitch scaling linear/log, what is the default interval range of sendPitchBend and how might I about changing that (or is that all done on the DAW side?
Any information about this would be greatly appreciated. Much thanks, everyone.
