PWM Output on Teensy 3.1 - Only 3 Channels or more possible? (incl. Custom Update Rat
Hello,
I am working on a project which uses the Audio library and PWM as control for analog filters, etc.
I read "The PWM signals are created by hardware timers. PWM pins common to each timer always have the same frequency, so if you change one pin's PWM frequency, all other pins for the same timer change.".
Is this still true? Does it mean that I can only use 3 PWM outputs (e.g. PIN3, PIN5, PIN25)? Or does this
only affect the PWM Update speed? (I want to use 31KHz Update Rate at 12 Bit).
Does the Audio Library also Interfere somehow with the PWM output or should it not be a problem if I use
AudioOutputAnalog or AudioOutputI2S?
Hello,
