I'm about to try a project using the Teensy 3.1, running WS2812 LEDs, that also needs an SD card. I have the OctoWS2811 card, all well and good. I also bought the Micro SD Card adaptor not noticing that it was set up for the Teensy 2.0, but I found the thread on using it with 3.1.
I'm looking now at the Wiz820+SD Adaptor card to use it without the Wiz ethernet, just to use it for the SD card interface, so I don't have to solder a custom board to adapt to the Micro SD Card Adaptor. There are plusses and minuses each way, and I'll probably use the Micro SD Card adaptor just because I can make it fit better physically. However, does anyone have any suggestions or advice about that?
More to the point, the OctoWS2811 and the Wiz820+SD Adaptor have a couple of pin conflicts, which I would assume (comments anyone?) would be the case even if I use the smaller Micro SD Card Adaptor. Specifically, pin 4 is used for CS for the SD card, which according to http://forum.pjrc.com/threads/16758-Teensy-3-MicroSD-guide can be redirected for the SD card to another pin. More to the point, the OctoWS2811 card uses pin 12IN (aka MISO in SPI terms) for the Frame sync pin. Can this pin be re-directed, and or just ignored (cut the trace) since I am not syncing this with any other units?
Any info or advice on combining these two would be helpful. I'm an old hand at 8051 micros (professionally since '89) but I'm new to Arduino. I've only done a couple of Arduino (Mega 2560) projects, and this is my first Teensy/ARM/Arduino project. I have not yet dug into code, I'm in the collecting info and parts phase, but I'm on a short time frame, this has to be ready for Burning Man in 3 weeks!
Thanks!
Thanks!
