I have purchased these components
teensy 3.1
octows2811 adapter
wiz820 SD adapter
wiz820io module.
I have found this diagram here by paul which shows how to hook the boards together for use with the VideoSDCard.ino example code.
https://github.com/PaulStoffregen/OctoWS2811/blob/master/examples/VideoSDcard/hardware.jpg
I want to do almost the same thing using the octows2811 library and this hardware, but want to also be able to stream video over ethernet as well as be able to read files from the sd card. This way I can connect to pc software to design animations and display over ethernet, then save them to files for playback via the SD card reader.
Will this hardware arrangement in the jpg work with a wiz820io module attached as well ?
Will I be able to access both sd card and ethernet at the same time, or at least one at a time ?
If anyone else has tried this and can give any advise here that would be great
thanks
Lynton
teensy 3.1
octows2811 adapter
wiz820 SD adapter
wiz820io module.
thanks
Lynton
