For anyone else coming to this thread, it's about this LED video panel we built for Freescale in May 2014.
http://community.arm.com/groups/embedded/blog/2014/05/23/led-video-panel-at-maker-faire-2014
I'm curious if you used any inline fuses?
No, but now that you mention it, that does sound like such a good idea. Those six power supplies are rated for a combined total of 240 amps of current.
The junction box that the power supplies are connected to, what is going on in there?
120 AC comes in, hot goes through a switch, and then feeds out to the 2 sides, powering up 3 power supplies on each side. It's really very simple.
What is the clear box for?
Spare parts.
Really, we made this thing for Freescale to take to Maker Faire and other shows. The box has a spare for every part, plus some tools and other supplies they might need. Apparently something did go wrong at some point when they took it to another show, maybe in Detroit, but they were able to get it back up and running by swapping out a part.
For the power that you are running to the strips are you using several spades under one post?
The wires are merely tinned and wedged under the screw terminals. Yes, several go to each post.
Is there anything you would do differently the next time around?
It actually went really well. Aside from charging 5X as much (we only billed them for materials, since they've been pretty helpful us on several occasions) and not trying to cram the entire build into only 3 weeks, I'd probably do it about the same.
