# UDEV Rules for Teensy boards, http://www.pjrc.com/teensy/
# The latest version of this file may be found at:
# http://www.pjrc.com/teensy/49-teensy.rules
# This file must be placed at:
# /etc/udev/rules.d/49-teensy.rules (preferred location)
# or
# /lib/udev/rules.d/49-teensy.rules (req'd on some broken systems)
# To install, type this command in a terminal:
# sudo cp 49-teensy.rules /etc/udev/rules.d/49-teensy.rules
# After this file is copied, physically unplug and reconnect Teensy.
ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789]?", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789]?", ENV{MTP_NO_PROBE}="1"
SUBSYSTEMS=="usb", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789]?", MODE:="0666"
KERNEL=="ttyACM*", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789]?", MODE:="0666"
# If you share your linux system with other users, or just don't like the
# idea of write permission for everybody, you can replace MODE:="0666" with
# OWNER:="yourusername" to create the device owned by you, or with
# GROUP:="somegroupname" and mange access using standard unix groups.
# If using USB Serial you get a new device each time (Ubuntu 9.10)
# eg: /dev/ttyACM0, ttyACM1, ttyACM2, ttyACM3, ttyACM4, etc
# apt-get remove --purge modemmanager (reboot may be necessary)
# Older modem proding (eg, Ubuntu 9.04) caused very slow serial device detection.
# To fix, add this near top of /lib/udev/rules.d/77-nm-probe-modem-capabilities.rules
# SUBSYSTEMS=="usb", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789]?", GOTO="nm_modem_probe_end"
# (old udev rules)
#SUBSYSTEMS=="usb", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="047[78]", MODE:="0666"
#SUBSYSTEMS=="usb", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="048[02]", MODE:="0666"
#KERNEL=="ttyACM*", SYMLINK+="ttyUSB00%n", MODE:="0666"
# old versions of librxtx within Arduino needed this extra symlink, new versions recognize "ttyACM"
#KERNEL=="ttyACM*", ATTRS{idVendor}=="16c0", ATTRS{idProduct}=="04[789]?", SYMLINK+="ttyUSB00%n", MODE:="0666", ENV{ID_MM_DEVICE_IGNORE}="1"
