Hello,
I want to use a Teensy 3.1 as a USB MIDI device (as emitter) and connect it to an iPad retina. The iPad won't connect to the Teensy. There is a message on the iPad stating that the Teensy cannot be powered by the iPad.
I know it's possible to establish the connection over a powered USB hub but I would prefer not to use a hub.
If I power the Teensy with a dedicated power adapter will the iPad refuse the connection too? In this case, is there any solution besides the hub ?
Thank you in advance.
