From Rainbow.ino:
" Required Connections
pin 2: LED Strip #1 OctoWS2811 drives 8 LED Strips.
pin 14: LED strip #2 All 8 are the same length.
pin 7: LED strip #3
pin 8: LED strip #4 A 100 ohm resistor should used
pin 6: LED strip #5 between each Teensy pin and the
pin 20: LED strip #6 wire to the LED strip, to minimize
pin 21: LED strip #7 high frequency ringining & noise.
pin 5: LED strip #8
pin 15 & 16 - Connect together, but do not use
pin 4 - Do not use
pin 3 - Do not use as PWM. Normal use is ok.
pin 1 - Output indicating CPU usage, monitor with an oscilloscope,
logic analyzer or even an LED (brighter = CPU busier) "
I'm confused by the use of the word 'required' and wonder if 'reserved' is a better alternative. Are *all* these pins reserved as part of the Teensy/Octo hardware combination or is their reservation also a function of the implementation in Rainbow.ino? The Octo board seems to allow connects to pin 1 (but which is used in Rainbow).
Also, to run this code correctly am I to bridge pins 15 and 16 or is this already handled?
Lastly, do i need to add 100 Ohm resistors as noted or are these already included in the Octo implementation
mb
pin 7: LED strip #3
pin 5: LED strip #8
pin 4 - Do not use
mb
