I'm trying to make a controller for a Cambridge Technology digital servo driving galvo mirrors in a 2-photon microscopy setup. The controller is required to generate signals following an SPI-like protocol with ~200 ns pulses for the clock, and data (CS/2channels) transmitted along the way. The commands consist of 16-bit words and have to be sent every 10 ms. Given the 72 MHz teensy 3.1 processor, it can be done. However, if the interrupts are not disabled, the code is interrupted from time to time (in quite a regular way), which screws up the controller.
Turning off the interrupts and timing everything with __asm__("nop\n\t") is an option, but makes the code ugly and very inflexible (at least, it is desirable to be able to use interrupts to schedule the 10 ms blocks).
The question is: Is it possible to turn the unnecessary teensy functionality off, without completely disabling interrupts? I've tried using (and modifying) the 'bare-metal' makefile-based deployments by Karl Lunt for Windows (link), as well as by Kevin Cuzner's makefile for Linux (link), but haven't succeed with either of them at the moment. However, the .hex file produced by Karl results in a completely predictable behavior of teensy (no unasked for interrupts), making me believe the 'bare-metal' deployment is a solution here.
I'd appreciate any suggestions.
Thank you,
Max
Thank you,
Max
