knuffiandy
iam new at teensy and in general in DSP.
I want to create a low pass FIR filter with a corner frequency at 100 khz. I calculated the filter with SCILAB and i have the correct bode curve and filter coefficients. In general i know the existing CMSIS lib. from ARM for Cortex-M4 processors.
A signal which should injected to the AD converter should be sampled and filtered with the DSP engine of Teensy.
My question is now if the AD converter is able to convert the signal without aliasing and could calculate the filter output without speed problems for continious application.
I dont know how to get a feeling or to calculate the max. possibilities for sampling and filtering of signals of teensy and for the max. MIPS of Teensy and for which application i need how many MIPS.
I know that the sampling rate must more as 2 x max. signal frequency of the analog signal.
cheers,
Andy
cheers,
Andy
