I would like to use the teensy audio card at 96 kHz and having the CPU running at 144 MHz
(initially without using the audio SW that is tuned to 44.1 kHz)
For this I have to setup the i2s system
my maths give me FRACT = 64-1; DIVIDE = 375-1; and DIV= 4-1;
with 144 MHz this should result in 96 kHz sampling.
While formally the registers can hold these values, I'm worried about the high FRACT value (upsamples the CPU).
Is this a problem?
Does someone have tested these high FRACT values?
Grazie,
Walter
Is this a problem?
Grazie,
Walter
