Hello,
I have several flex sensors I want to connect to the Teensy's analog inputs.
I plan to use the AREF pin in order to adapt the range of the conversion to the sensor's voltage range (each sensor being inserted in a voltage divider). However I am not sure about the best solution to provide a stable reference voltage.
First, I have several possible voltage sources.
1. My circuit will include a Pololu switching step-up regulator which will provide 5V to the Teensy and to some other components.
2. The Teensy's 3.3V output.
3. An additional shunt regulator (TL431).
Would any of them be stable enough ? Which one would be the best ?
Second, as I want the possibility to adjust the voltage, I planned to feed the AREF over a voltage divider including a trimmer. Any recommendation about this ?
Thank you in advance.
