I'm trying to mock Paul's capacitive sensor project at https://www.pjrc.com/teensy/td_libs_CapacitiveSensor.html. The problem I'm having is using the view of Paul's prototype and understanding which pins the resistors connect to on the pcb. Also, since I can't control the inputs, I can't discover which outputs to connect to my bilateral switch (4066). My version of the Teensy 2.0 board shows GND and pins 0-10 on one side and VCC and pins 11-21 on the other. Other board layouts I've discovered show the Teensy 2.0 with GND and pins 0-12 on one side and VCC and pins 13-25 on the other. What I need to know is the pins that represent TX1 and RX1, TX2 and RX2, TX3 and RX3, and the corresponding outputs they control for my version of board. Also, I'm thinking of creating sensors by using two pieces of copper foil separated by plastic food wrap or wax paper and connecting one piece of foil to the junction of the resistors and the other to power supply GND. Hopefully I've expressed myself well enough to gain a usable response. Thanks!
