Hey all, longtime lurker here posting for the first time. Just switched from Arduino to Teensy. Here's my situation:
Software:
Win7
Arduino 1.6.5r2
Teensyduino 1.24
Hardware:
Teensy 3.1
WIZ820io & Micro SD Card Adaptor
WIZ820io
I am attempting to get this stack to communicate over Ethernet. The first sketch I was trying to run to confirm that everything works is the Ethernet library's WebServer example. (code found here: https://www.arduino.cc/en/Tutorial/WebServer)
I changed nothing in the example code and gave it a run, and here is my output in the serial monitor:
Okay, I thought, not getting an IP. Here's what I've done so far to debug:
-Confirmed that the Teensy was plugged into an active Ethernet port.
-Connected said active Ethernet port straight to my router as opposed to the switch it was connected to.
-Changed the example code's IP and MAC address several times.
-Tested the continuity of each pin from the WIZ820io module to the Adapter and finally to the Teensy with a multimeter.
-Made sure that the WIZ module and adapter module are connected in the proper orientation.
-Confirmed that no SD card was plugged into the adapter.
-Added these lines of code to the start of the WebServer's setup routine as suggested by the adapter's PJRC website page:
-Ran an example sketch from the SD library to ensure that the SD portion works. (Successfully printed out a directory listing of an SD card I had lying around)
After all that, I'm led to believe that my WIZ820io module is not working properly.
When the Teensy is plugged in and running the WebServer sketch, the two lights on the Ethernet jack light up. The green one is solid and the orange flashes periodically. Connection and activity, I presume.
So, with the idea that the WIZ module is faulty, I decided to hook it up to an Uno I had lying around and use the same WebServer sketch to see if it would work there. No dice. Not even getting the two leds on the jack to light up.
I guess my question is - do you think that this module is indeed DOA, or have I missed something? I figured I would post here before I RMA the thing.
Thanks!
Software:
Win7
Arduino 1.6.5r2
Teensyduino 1.24
Hardware:
Teensy 3.1
WIZ820io
server is at 255.255.255.255
pinMode(4, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
delay(1); // allow time for both pins to reach 3.3V
Thanks!
