qwazzerman
I just got two Teensies (3.1), and my computer has trouble recognizing one of them (Teensy A). I've soldered pin headers and a crystal for the RTC. When I connect it via USB, there's no sound that something has been plugged in, the device manager doesn't change to show a new device, and nothing new appears under "Devices and Printers". However, I can upload sketches to it that seem to run: while I can't get the serial output to work, if I upload Blink, the LED blinks like normal. If I press the button, the computer plays the 'device connected' sound and the Device Manager refreshes, but then nothing new appears. If I connect Teensy A to a different computer (Teensyduino not installed), nothing happens until I press the button, at which point it recognizes that something is connected and starts searching for drivers. Currently, Teensy A has the default HelloSerialMonitor sketch loaded.
The second Teensy (Teensy B), fresh from the package. When I connected THAT one for the first time, Windows immediately recognized that something was plugged in and commenced to searching for a driver. Once the driver installed (which required a restart), it shows up in the Device Manager as "HID-compliant device" and appears in "Devices and Printers" as "Teensyduino RawHID" whenever connected. Teensy A still is not recognized by Windows, but I can still write sketches to it.
Both Teensies are set to "USB type: Raw HID", which (if I'm correct) is what I want for Serial.print, since Teensy isn't actually communicating through serial over USB.
I've tried the Serial Driver Installer and reinstalling from the Teensyduino installer.
Is there a way to find whatever settings/drivers/whatever that are associated with Teensy A and reset it so that Windows can install it correctly?
