<edit>
Whoops, I forgot to enable the two spreadsheets so that anybody can view them. I just fixed that, and changed the links to be the sharable links.
Teensy-LC tab is done, I'm working on the Teensy 3.1 tab, it will look jsut like the LC tab once it's finished.
I've used photos of the actual devices and colouration from the referencecard in a combined solution. I find this the easiest way for me, particularly once the breadboard is all wired up and busy.
Edit: it looks a bit messed up at the bottom in the dropbox preview. Opening it in Excel will give you the required polish, text alignment and perfect image scaling.
