I'm having some issues with Teensy boards dying, seemingly at random. I'm using the board as an always on temperature controller and have had it running for about a year. In that time, I've gone through 3 boards. First a Teensy 3.0 and then 2 3.1's. I swapped the first two boards out and the third died yesterday. The setup runs wonderfully for months on end and then I'll look at it one day and find that the board is no longer functional (no longer running code and non-responsive over the serial connection). Setup is very simple, 9 output pins connected to a relay board and one pin for 1-wire communication to some DS18B20's. I cut the trace to separate VUSB and the board is powered from a 5V power supply in the enclosure. I'm going to order another couple of boards to get back up and running, but it seems like a board should last more than a few months. Anyone out there have any suggestions for things to check?
