oran.outan
hi
I work on teensy 3.1 + ethernet module USR-ES1 with wiznet 5500 (http://www.usr.so/Product/93.html).
i first try with arduino Uno board and was running well… then moved to teensy, and that was not running… so normally I can used same code !
after some look on internet try this issue :
- 3.3v external power
- Reset connection ::: but that part is not clear for me ( and with the uno the ethernet module run well without the reset connection).
Does it need to be HIGH and when ?
for the rest i have follow wire instruction, whose work well on Uno test… just not used the reset wiring…
10:CS --> SS
11OUT --> MOSI
12IN --> MISO
13:SCK --> SCLK
gnd --> gnd
3.3 --> 3.3
9 --> reset ???
My goal is to send osc message over udp using MAx/msp, just add a led on pin 3 for test...
here is the code i used :
i used arduino 1.6.5 and teensyduino 1.25, without error compilation
if you have some ideas to fix it it's really welcome…
all the best
10:CS --> SS
11OUT --> MOSI
12IN --> MISO
13:SCK --> SCLK
gnd --> gnd
3.3 --> 3.3
9 --> reset ???
HTML:
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <OSCMessage.h>
#include <OSCBoards.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(169, 254, 129, 204); // ip to send to arduino
unsigned int InPort = 8888; // port to send on
EthernetUDP Udp; // An EthernetUDP instance to let us send and receive packets over UDP
//================================================================ SETUP =================================
// start the Ethernet and UDP:
Ethernet.begin(mac,ip);
Udp.begin(InPort);
Serial.begin (9600);
pinMode(3, OUTPUT);
pinMode(9, OUTPUT); // wire to reset on wiz module
//digitalWrite(9, HIGH); // ???? high ???
Serial.println("Setup");
// ============================================================== LOOP ====================================
OSCMessage messageIN;
int size;
if((size = Udp.parsePacket())>0){
while(size--){
messageIN.fill(Udp.read());
Serial.println("aaa");
if(!messageIN.hasError()) {
messageIN.route("/led", manageOSCMess_leds); // message from MAx = /led [0/1]
Serial.println("ccc");
void manageOSCMess_leds(OSCMessage &msg, int addrOffset ){
Serial.println("Trigger signal received");
if (msg.isInt(0)){
int i = msg.getInt(0);
digitalWrite(3, (i > 0)? HIGH: LOW);
all the best
