Hello,
I'm using a teensy 3.1 together with WIZ820io, I use Paul Stoffregen's Ethernet library for W5200. I'm able to send UDP packet from the teensy to my computer without problem, but the SCK pin used is 13, and I would like to use pin 14. I tried to modify w5100.cpp by adding SPI.setSCK(14); like this :
But this does not solves my problem.
Have you got an idea how to use pin 14 for SCK signal ?
Thank you for your help !
Cheers !
Julien.
#ifdef USE_SPIFIFO
SPI.setSCK(14);
SPI.begin();
SPIFIFO.setSCK(14);
SPIFIFO.begin(W5200_SS_PIN, SPI_CLOCK_12MHz); // W5100 is 14 MHz max
#else
SPI.setSCK(14);
SPI.begin();
SPI.setClockDivider(SPI_CLOCK_DIV2);
initSS();
Cheers !
Julien.
