I want to create a control box that will run off a battery and monitor sensors every minute or so and log the results to an SD card. The logged results will need to contain values and a timestamp. There will also be an LCD readout (over serial) that can be controlled by a keypad (possibly over serial) that will allow the operator to set the time/date info and manually check the logs. When there is no operator then the keypad and LCD will be turned off to conserve battery life. I ordered a Teensy ++2.0 and got the LCD up and running and discovered that there is no RTC, I know, I know, a slow-witted move. I am now looking at using a Teensy 3.2 because it has a built in RTC. As far as power consumption is concerned, is it better to add a RTC to the 2.0 or go on up to the 3.2? Also, if I want to control 2 serial devices and log the data to an SD card does that make the 3.2 a better option? Power consumption is a big deal, as I would like the unit to run for a month or so on a 12V 5Ah battery. I only need to collect the data every minute or so and I plan on putting the controller to sleep and waking on a timed interrupt. I apologize if I left out too many details, I am new at this and I appreciate the advise of all you pros out there. Thanks and have a nice Thanksgiving.
