joe_prince
The datasheet for the ATMEGA32U4 (http://www.atmel.com/Images/Atmel-7766-8-bit-AVR-ATmega16U4-32U4_Datasheet.pdf) doesn't mention the bottom ground pad for the QFN package. Besides for thermal reasons, does the bottom pad need to be connected to ground (i.e., is it not already electrically connected to the other GND pins)?
On the Teensy 2.0 it appears that it is connected (with an array of vias on the pad area to dissipate the heat), but on other boards like the Arduino Micro and SparkFun's Pro Micro (https://www.sparkfun.com/products/12640) the bottom pad doesn't appear to be connected at all, at least not with an array of vias going to the back side of the board. I understand soldering the exposed bottom pad helps with structural stability, but I'm more concerned with the electrical connection.
So, the question is, do I need to connect the bottom ground pad?
