Im curious, at what bit resolution do the PEAK and FFT functions operate at? Is it at the standard 10bit resolution?
I know the output from PEAK and FFT are from 0 to 1. To what decimal place will these measure down to?
For example, doing an analog read on a pin, is by default set to 10bit. But can be increased. Is it also possible to increase the resolution of the PEAK and FFT readings?
Thanks for the insight!
