View Full Version : Why cant i play this file on the Teensy audio card
toreil
01-02-2016, 12:44 PM
Hi.
Compiled some wav files with Natural Reader, but cant plsy then.
The example files SDTEST1.. works fine
Tried a lot of Wav settings but NO Go..
Had to rename sample1.wav to .txt to upload.
Tore
PaulStoffregen
01-03-2016, 12:19 PM
I'm listening to it play here on a Teensy 3.1 with audio board. It's saying "Hi, this" over and over again.
Here's the code I'm running. Maybe copy this into Arduino and run it on your board?
#include <SerialFlash.h>
AudioPlaySdWav playWav1;
AudioOutputI2S audioOutput;
AudioConnection patchCord1(playWav1, 0, audioOutput, 0);
AudioConnection patchCord2(playWav1, 1, audioOutput, 1);
// Use these with the audio adaptor board
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
playWav1.play("SAMPLE1.WAV");
delay(2500);
In your code, check the filename. The Arduino SD lib only knows 8.3 names, which are all uppercase. If you used lowercase letters in your code, it won't be able to find the file.
toreil
01-03-2016, 01:29 PM
Hi.
Thanks for grate support.
But my original code looked ok, but it seems to be a problem with BIG and smal letters in the filename, and code
Dont know if thst makes any scence,, but its working now...
Thanks
Tore
