I've used Teensy 2's & 3's with a number of LED projects, but now I'm investigating using one for a 4-channel 44.1 kHz data logger.
It seems the capability of 4 channel input is now available, so I presume that requires 2 audio boards.
Also I would like to record several days of data, so two 32GB SD cards will probably not be enough. Ideas? Is there enough bandwidth?
And, as this system will be running on batteries, I need to estimate total power consumption so I can size the battery.
Help greatly appreciated...
Loren Carpenter
Loren Carpenter
