I'm running the following code on my Teensy LC:
In the serial monitor, if I type in any characters, I get the error:
Assuming this is a problem with the Arduino IDE serial implementation, I'd like to move away from the Arduino IDE serial monitor. However, the teensy LC does not show up as a COM port.
Here is where I get very confused... a friend of mine swears that he's used the teensy LC on windows through a traditional com interface, but reading this thread: https://forum.pjrc.com/threads/32862-HID-device-to-COM-Port it seems like it should not enumerate as a COM port.
I've run the serial_installer.exe file several times, as administrator, but the device still does not show up as a COM port. I can see it under HID devices. If I had the *.inf file, I could force it to use that, but I can't find this file anywhere.
I'm using Windows Vista and Arduino 1.6.7.
char inByte = Serial.read();
// don't print character if not printable
if(inByte>33)
Serial.print(inByte);
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerExceptionat processing.app.Serial.write(Serial.java:191)
at processing.app.Serial.write(Serial.java:211)
at processing.app.TeensyMonitor.send(TeensyMonitor.java:95)
at processing.app.TeensyMonitor.access$100(TeensyMonitor.java:36)
at processing.app.TeensyMonitor$2.actionPerformed(TeensyMonitor.java:72)
at javax.swing.JTextField.fireActionPerformed(JTextField.java:508)
at javax.swing.JTextField.postActionEvent(JTextField.java:721)
at javax.swing.JTextField$NotifyAction.actionPerformed(JTextField.java:836)
at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1663)
at javax.swing.JComponent.processKeyBinding(JComponent.java:2882)
at javax.swing.JComponent.processKeyBindings(JComponent.java:2929)
at javax.swing.JComponent.processKeyEvent(JComponent.java:2845)
at java.awt.Component.processEvent(Component.java:6312)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1954)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:806)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1074)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:945)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:771)
at java.awt.Component.dispatchEventImpl(Component.java:4762)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
