* @brief Initialization function for the Q15 FIR filter.
* @param[in,out] *S points to an instance of the Q15 FIR filter structure.
* @param[in] numTaps Number of filter coefficients in the filter. Must be even and greater than or equal to 4.
* @param[in] *pCoeffs points to the filter coefficients.
* @param[in] *pState points to the state buffer.
* @param[in] blockSize number of samples that are processed at a time.
* @return The function returns ARM_MATH_SUCCESS if initialization was successful or ARM_MATH_ARGUMENT_ERROR if
* <code>numTaps</code> is not a supported value.
arm_status arm_fir_init_q15(
arm_fir_instance_q15 * S,
uint16_t numTaps,
q15_t * pCoeffs,
q15_t * pState,
uint32_t blockSize);
