FIR filter doesn't work after using TFilter design tool
josechow
Code below works for pass thru, and compiles for implementing the low pass filter, but does not output anything on the dac or respond to serial. I am at a loss. Does the filter need to be of a specific size? I only saw the max of 200 constraint
AudioInputAnalog         audio_in(A3);   //xy=179,383
AudioFilterFIR           fir1;           //xy=342,383
AudioOutputAnalog        dac1;           //xy=519,360
AudioRecordQueue         amdf_samples;   //xy=543,409
AudioConnection          patchCord1(audio_in, fir1);
AudioConnection          patchCord2(fir1, dac1);
AudioConnection          patchCord3(fir1, amdf_samples);
FIR filter designed with
http://t-filter.appspot.com
sampling frequency: 44100 Hz
fixed point precision: 16 bits
* 0 Hz - 6000 Hz
  gain = 1
  desired ripple = 5 dB
  actual ripple = n/a
* 15000 Hz - 22050 Hz
  gain = 0
  desired attenuation = -60 dB
  actual attenuation = n/a
#define FILTER_TAP_NUM 11
const short filter_lowpass[FILTER_TAP_NUM] = {
  -779,
  -2839,
  -2707,
  5409,
  19375,
  26657,
  19375,
  5409,
  -2707,
  -2839,
  -779
unsigned long last_time = millis();
  delay(300);
  // allocate memory for the audio library
  AudioMemory(100);
  //fir1.begin(FIR_PASSTHRU, 0);
  // Initialize the filter
  fir1.begin(filter_lowpass, FILTER_TAP_NUM);
  // print information about resource usage
  // Proc = 18 (18),  Mem = 4 (5)
  if (millis() - last_time >= 2000) {
    Serial.print("Proc = ");
    Serial.print(AudioProcessorUsage());
    Serial.print(" (");
    Serial.print(AudioProcessorUsageMax());
    Serial.print("),  Mem = ");
    Serial.print(AudioMemoryUsage());
    Serial.print(" (");
    Serial.print(AudioMemoryUsageMax());
    Serial.println(")");
[SOLVED] filter declaration must be of an even number
Used the default example and just started cutting down the number of sample points and it turns out odd number of filter elements caused failures. Re-ran the tfilter design tool and added 1 to the minimum number of elements.
Though, I would like to know if the number of delay elements would reduce or increase the stability of the filter?
* 0 Hz - 6000 Hz
  gain = 1
  actual ripple = n/a
  gain = 0
const short FILTER_TAP_NUM = 12;
const short filter_taps[FILTER_TAP_NUM] = {
  -369,
  -2022,
  -3644,
  171,
  12206,
  24284,
  24284,
  12206,
  171,
  -3644,
  -2022,
  -369
