dxinteractive
Hi, I'm using a Teensy to make a little multi effects unit. In this I'm planning to have "modes", where each mode is basically a set of effects / mixers etc with connections between them. A couple of buttons will allow selecting a different mode during program execution. No need for two modes to run at the same time, however a mode will obviously contain multiple AudioStream and AudioConnection objects. It'd be cool to choose a Chorus effect and then flick over to a Low Pass Filter etc. all in one little box.
Now there are two ways I can think of making something like this work.
So right now I'm aiming for option 1. Any ideas if that's possible? So far I've thought of a couple of things:
- Create necessary AudioStream and AudioConnection objects when changing to a new mode. This requires the ability to remove those objects later when a different mode is selected. Also need to allocate objects on the heap, I've never seen examples do this but it seems to work. Not sure how it affects performance.
- Create all AudioStream and AudioConnection objects and set up a mechanism to allow most presets to be bypassed at any given time. This seems wasteful (not sure if it actually is), and given the amount of modes I want to potentially use (hopefully 10-20!) I'm not sure if it's a suitable option. I don't know just how much memory or processor usage these objects take up if they are bypassed, or even if there is a mechanism to toggle an AudioStream object to be bypassed or not.
- it looks as though a AudioConnection::disconnect() method would have to be created to complement AudioConnection::connect().
- Do AudioConnection or AudioStream objects get added to any register-style objects that they would need to be de-registered from? The comment on the docs that says "Connections are most efficient when made from an earlier object (in the order they are created) to a later one" makes me think there is a little magic going on behind the scenes that I should probably be aware of.
