#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
#define txPin 2
#define MeterMode 18
#define MeterBlank 19
#define LevelLatch 20
#define SPICLOCK 21
#define SDOUT 22
#define SOUT 23
#define PCKT_LEN 65535 // the packet length 16 bits
SoftwareSerial LCD = SoftwareSerial(0, txPin);
//const int buttonState = 26;
//int state = 0;
uint8_t receivedVAL1;
uint8_t receivedVAL2;
uint8_t receivedVAL3;
uint8_t receivedVAL4;
uint8_t LEDs1 = 0;
uint8_t LEDs2 = 0;
byte LEDs3 = 00000000;
byte LEDs4 = 00000000;
SPISettings settingsA(125000, MSBFIRST, SPI_MODE1); //(gives 8 microsecond period clock pulses)
//SPI.beginTransaction(SPISettings(125000, MSBFIRST, SPI_MODE3)); // to begin using the SPI port. The SPI port
void clearLCD(){
LCD.write(0xFE); //command flag
LCD.write(0x01); //clear command.
delay(10);
char buffer[PCKT_LEN];
//Serial.begin(9600);
LCD.begin(9600);
pinMode(txPin, OUTPUT);
pinMode(LevelLatch, OUTPUT);
pinMode(MeterMode, OUTPUT);
pinMode(MeterBlank, OUTPUT);
digitalWrite(MeterMode, LOW); // connected to ON/OFF controll keep constant - digitalWrite(MeterBlank, HIGH); // all LEDs OFF
digitalWrite(MeterBlank, LOW); // ON/OFF of OUTx outputs are controlled by input data
// SPI.transfer(0xCC);
SPI.begin();
// SPI.beginTransaction(settingsA);
// digitalWrite(SPICLOCK, LOW);
for (int i=0; i<PCKT_LEN;i++)
SPI.transfer(buffer[i]);
digitalWrite(LevelLatch, HIGH);
digitalWrite(LevelLatch, LOW);
clearLCD();
LCD.print("OUTPUT");
LCD.print(digitalRead(SOUT));
LCD.print(data, BIN);
delay (2000);
clearLCD();
LCD.print(ner, BIN);
delay (2000);
// digitalWrite(MeterMode, LOW);
LEDs1 = 0; // 0x00 = 00000000
LEDs2 = 255;
LEDs3 = 0x00;
LEDs4 = 0x00;
receivedVAL1 = SPI.transfer(255);
receivedVAL2 = SPI.transfer(255);
receivedVAL3 = SPI.transfer(1);
receivedVAL4 = SPI.transfer(LEDs4);
// digitalWrite(LevelLatch, HIGH);
lcdPosition(0,0);
LCD.print("passed to here");
delay (1000);
lcdPosition(1,0);
LCD.print(receivedVAL2, BIN);
LCD.print(receivedVAL3, BIN);
// LCD.print(receivedVAL3, BIN);
delay (1000);
// LCD.print(receivedVAL4, BIN);
clearLCD();
// wbp: goto with row & column
void lcdPosition(int row, int col) {
LCD.write((col + row*64 + 128)); //position
delay(10);
May as well use SPI
These TLC chips have a bitch of a configuration data register though. 7 bits of dot correction data.
At least that's exactly 14 bytes. The TLC5955 is 96 bytes and 1 bit or something
Standard operation is just a 16 bit shift register which should work with shiftout if you do want bitbanging
pinMode(TLC_Latch, OUTPUT);
digitalWriteFast(TLC_Latch, LOW);
SPI.begin();
// All on
SPI.transfer(255);
SPI.transfer(255);
digitalWriteFast(TLC_Latch, HIGH);
delay(5);
// All off
SPI.transfer(0);
SPI.transfer(0);
delay(5);
Yes that is the case.It looks like I do not need to worry about clock and Meter mode and meter blank. Are those done automatically with SPI?
I'm glad it worked for you!
If you wish to change brightness You'll have to do 14 SPI.transfer()s and a latch up->down whilst the mode pin is high. This will write the dot correction data
EDIT -
Actually meterblank isn't covered by SPI or my code. You normally don't need this pin
#define txPin 2
#define TLC_Latch 20
#define SPICLOCK 21
#define SDOUT 22
#define SOUT 23
const int LCDdelay=10; // conservative, 2 actually works
digitalWrite(TLC_Latch, LOW);
SPI.begin();
digitalWrite(MeterMode, LOW); // connected to Dot connection
LCD.begin(9600);
clearLCD();
LCD.print("Ready to test?");
// set all LEDs off
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0);
digitalWrite(TLC_Latch, HIGH);
delay(5);
delay(2000);
clearLCD();
LCD.print("Color");
// set all LEDs on
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(255);
delay(5);
delay(2000);
clearLCD();
LCD.print("Brightness low");
// set brightness to lowest
digitalWrite(MeterMode, HIGH);
delay(5);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0);
SPI.transfer(0);
delay(5);
delay(1500);
clearLCD();
LCD.print("Brightness high");
// set brightness to highest
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(255);
delay(5);
delay(1500);
void clearLCD(){
delay(LCDdelay);
#include<SoftwareSerial.h>
#define txPin 45
#define LED_POW 44
#define MeterMode 38
#define SPICLOCK 21
#define SDOUT 22
#define LCD_E 1
#define LCD_RW 0
#define LCD_RS 27
#define SW_408 42
int SW = 0; // Switch selected on the DUT board
int test=0;
int SelectSW = 0; //select unit 408 or 816
SoftwareSerial LCD = SoftwareSerial(0, txPin); // since the LCD does not send data back to the Arduino, we should only define the txPin
pinMode(SW_408, INPUT);
pinMode(LCD_RW, OUTPUT);
pinMode(LCD_RS, OUTPUT);
pinMode(LCD_E, OUTPUT);
SPI.begin();
LCD.begin(9600);
LCD.print("Testing");
selectUnit();
AllLEDsOFF();
clearLCD();
LCD.print("testing switch board");
LEDsRow1();
LEDsRow2();
LEDsRows3and4();
LEDsRow5Red();
LEDsRow5Green();
clearLCD();
LCD.printf("Lsst LEDs should be red");
//SW_LEDs red
for (int i=0; i<SelectSW; i++){
SPI.transfer(15);
SPI.transfer(255);
DoubleSpi(85);
DoubleSpi(0);
DoubleSpi(0);
Latch();
delay(2000);
clearLCD();
LCD.printf("All LOW");
for (int j=0; j<28; j++){
SPI.transfer(1);
for (int k=0; k<14; k++){
SPI.transfer(0);
for (int l=0; l<14; l++){
SPI.transfer(0);
Latch();
delay(10000);
clearLCD();
LCD.print("ALL HIGH");
for (int j=0; j<14; j++){
SPI.transfer(127);
for (int k=0; k<28; k++){
SPI.transfer(127);
SPI.transfer(127);
Latch();
delay(2000);
clearLCD();
LCD.print("End Brightness");
}//end of loop
void AllLEDsOFF(){
clearLCD();
LCD.printf("All LEDs OFF");
for (int j=0; j<6; j++){
SPI.transfer(0);
DoubleSpi(0);
Latch();
void AllLEDsON(){
clearLCD();
LCD.printf("All LEDs ON");
SPI.transfer(255);
SPI.transfer(255);
SPI.transfer(85);
SPI.transfer(85);
SPI.transfer(255);
SPI.transfer(255);
DoubleSpi(0);
Latch();
void clearLCD(){
LCD.write(254); //command flag
LCD.write(81); //clear command.
delay(LCDdelay);
void selectUnit(){
if (digitalRead(SW_408)) {
SelectSW = 1;
clearLCD();
LCD.print("Testing Galaxy 408");
delay(3000);
if (!digitalRead(SW_408)) {
SelectSW = 2;
clearLCD();
LCD.print("Testing Galaxy 816");
delay(3000);
void LEDsRow1(){
LCD.printf("First row LEDs should be red");
// LED101-LED116 first four red
for (int j=0; j<4; j++){
SPI.transfer(0);
DoubleSpi(17);
DoubleSpi(0);
Latch();
void LEDsRow2(){
clearLCD();
LCD.printf("Second row LEDs should be orange");
// LED101-LED116 second four orange
SPI.transfer(240);
for (int j=0; j<3; j++){
SPI.transfer(0);
DoubleSpi(34);
DoubleSpi(0);
Latch();
void LEDsRows3and4(){
clearLCD();
LCD.printf("Last two rows LEDs should be green");
// LED101-LED116 last eight green
DoubleSpi(0);
DoubleSpi(0);
DoubleSpi(204);
DoubleSpi(0);
Latch();
void LEDsRow5Red(){
clearLCD();
LCD.printf("LEDs should be red");
//LEDs1-8 red
DoubleSpi(0);
DoubleSpi(85);
DoubleSpi(0);
DoubleSpi(0);
Latch();
void LEDsRow5Green(){
clearLCD();
LCD.printf("LEDs should be green");
// LEDs1-8 green
DoubleSpi(0);
DoubleSpi(170);
DoubleSpi(0);
DoubleSpi(0);
Latch();
void LEDsSW(){
clearLCD();
//SW_LEDs red
SPI.transfer(15);
SPI.transfer(255);
DoubleSpi(0);
DoubleSpi(0);
DoubleSpi(0);
Latch();
void Latch() {
delay(5);
void DoubleSpi(int Spi){
SPI.transfer(Spi);
SPI.transfer(Spi);
const uint32_t NUMTLCS = 5; // Number of TLCs connected in series on SPI
SPI.begin();
// All on
for(uint32_t i = 0; i < NUMTLCS; i++) {
for(uint32_t i = 0; i < 14; i++) {
SPI.transfer(0xFF);
delay(5);
// All off
SPI.transfer(0x00);
delay(5);
This is my code that works for color only
