Audio Library for SN76489 Sound Generator
db-electronics
Hi all,
First time poster here, I've been working on a SN76489 (sound chip in Sega Master System, Colecovision, etc...) implementation for Teensy these last few days. I was inspired to do this when I saw the SID implementation library on this forum. I figured why not make a library for my favourite system!
I've got the code working with playback of a VGM file (intro music to the Sonic The Hedgehog game on Master System). VGM is a 44100Hz sample-accurate logging format which logs the data written to the sound chips by various game consoles. You can preview this by loading the PlayVGMFromMemory example sketch provided with the library - the VGM file is provided as a header file included in the example sketch.
Currently the VGM playback is from Teensy ROM but it will be trivial to add playback of *whichever* file from an SD card.
Github:
https://github.com/db-electronics/TDSN76489
Next I want to port code for the Yamaha YM2413 to Teensy, this FM synthesizer IC was used in the Japanese version of the Sega Master System.
