chorus ?
Frank B
Senior Member
i tried the chorus-effect. Is that really a chorus ? (buggy??)
It sounds more and more "digitally" the more "num_chorus" or memory i add. Or, is this intended ?
...hm... the sourcecode shows only delays, no pitch shift per "voice", this can't work (obviously, as you can hear)
What ever this effect is, it's not a chorus :-( Perhaps the same can be done with the delay-effect.
Looking over the source, yeah, that looks like a set of static comb filters. Something like the multi-tap delay line followed by a mixer.
Take a look at the Flanger class. It has sinusoid modulation and interpolation. Flange with slow modulation and overall delay of 25-ish milliseconds moves into chorus territory.
all you need to know about chorus
evidently a lfo modulates a clock signal, giving variable delay times. From the page ....
"The chorus effect is created by the slow modulation of the delay time using a Low Frequency Oscillator (LFO). As the LFO cycles, the delay time goes up and down and therefore the delayed audio pitch slightly shifts up and down."
Sounds a bit like how imagined a flanger would work ....
the delay is a bucket brigade device (whatever the hell that is)
You don't happen to have MIJ HM-2 source-code??
