benscammell
So if you have a switch with an RGB LED in it... I'm trying to work out how to interface multiple RGB buttons.
I've debated a ATtiny uC with the RGB LED and switch hung off it which in turn connects to Teensy over I2C with a common interrupt line, so if a button is pressed the ATtiny pings the common interrupt pin on the Teensy so it knows to read the state of all the buttons over the I2C... to see which one was pressed.
Thoughts?
Ben
Thoughts?
Ben
